You might want to throw a mic on the crank to make sure there's no taper on the journals. I had one that 'greew' .0015 (yes, one and a helf thousandths) from the oil hole to where the radius started.
Just something to look out for.
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
