Re: Rod Big End clearance problem??????
[Re: DemonDust]
#440119
08/16/09 06:47 PM
08/16/09 06:47 PM
Posts: 916 MB,CAN
PC-CHARGER
MB,CAN
Your picture is pretty tough to see but it looks like there is very little that needs to be removed. The proper tool is a bearing scraper like this: http://www.etoolcart.com/bearingscraper.aspxBut if you go slow and easy, a good sharp knife and some patience will work.
[Re: DemonDust]
#440120
08/16/09 06:47 PM
08/16/09 06:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What is the best way to narrow the bearings?
I've cut them with a knife to increase the chamfer
[Re: DemonDust]
#440123
08/16/09 07:08 PM
08/16/09 07:08 PM
MR_P_BODY
Would a utility knife with a new blade do the trick?
Yes... just light pressure.... your just scrapping it, it scraps easy
[Re: MR_P_BODY]
#440124
08/16/09 07:28 PM
08/16/09 07:28 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
Maybe practice with an old bearing first.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: dodgefarmer]
#440127
08/16/09 08:18 PM
08/16/09 08:18 PM
Check to see if your bearings are marked upper and lower.
Randy
same thing i was thinking. might have one or both in the wrong place.
#440128
08/16/09 09:02 PM
08/16/09 09:02 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
You might want to throw a mic on the crank to make sure there's no taper on the journals. I had one that 'greew' .0015 (yes, one and a helf thousandths) from the oil hole to where the radius started.
Just something to look out for.
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
