So how did you race with a clutch flite? #438066
08/14/09 09:48 PM
08/14/09 09:48 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
Seen one for sale in the classifieds.
Burn out box procedure?
Launch procedure?
Just wondering, hate to sound dumb, but I dont know how it works. I assume you launch with a clutch, and shift as normal?
Re: So how did you race with a clutch flite? [Re: Bob_Coomer] #438067
08/14/09 10:26 PM
08/14/09 10:26 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Can't say about racing with one but a friend of mine years ago had one that he drove on the street. Just as you said let the clutch out to go, manual shift through the gears, push in the clutch again to stop. He did race it ocasionally without any problem.
Re: So how did you race with a clutch flite? [Re: Bob_Coomer] #438068
08/14/09 10:47 PM
08/14/09 10:47 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Violently With no torque converter to cushion shifts they HAMMER the driveline. Not my idea of a street trans, and I sure wouldn't want to race one that didn't have bolt in sprag, good drums, etc. And 2 trans blankies
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: So how did you race with a clutch flite? [Re: Bob_Coomer] #438069
08/15/09 12:43 AM
08/15/09 12:43 AM
Launch procedure?
burn outs like regular, start it in second and shift it into high Launch procedure, rev it to where you want to let the clutch out(the clutch drives the front pump now so there is no internal trans pressure until the clutch is released, it acts like like a stick set up ) and shift it at the RPM you want like a regular 3 speed automatic Real old technology, best left in the old days The new converters are way better now than back then, that is probally the main reason there(clutch type automatic trans.) no longer around or in use today
Re: So how did you race with a clutch flite? [Re: Cab_Burge] #438070
08/15/09 01:12 AM
08/15/09 01:12 AM
my own world
theraif Offline
theraif  Offline
my own world
Couple yrs ago i asked is i could use a clutch flite in a manual shift class and was told no but i could run a lenco
Re: So how did you race with a clutch flite? [Re: theraif] #438071
08/15/09 01:16 AM
08/15/09 01:16 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
So can the trans shift on it's own or does it have to be manually shifted?
If I ever actually found one close to me, I had considered that putting one in my stick car might be kinda cool. But not if it cost a ton and was more likely to break stuff.
I want my fair share
Re: So how did you race with a clutch flite? [Re: SomeCarGuy] #438072
08/15/09 01:23 AM
08/15/09 01:23 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
manually shifted.
Nautilus Racing-
Re: So how did you race with a clutch flite? [Re: Bob_Coomer] #438073
08/15/09 06:17 AM
08/15/09 06:17 AM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
Launch procedure?
Bob, Peanut Stephens, (your neighbor) had one in a Devin sports car. It was equipped with a Hemi and injectors. He had the car at World of Wheels this year. The car has not been raced in over 30 years but he made a pass at Clay City last year. 426 Hemi with a NASCAR type bathtub intake and 4500 now insted of injectors. He lives between Greenup and Greenbow Lake. I will get his phone number for you.
Re: So how did you race with a clutch flite? [Re: Cab_Burge] #438074
08/15/09 08:50 AM
08/15/09 08:50 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Launch procedure?
I believe the pressure plate drives the pump gears so the pump is always making pressure to keep the forward clutch applied and the input shaft is spline into the clutch disc that's what keeps the car from moving when clutch is pressed
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: So how did you race with a clutch flite? [Re: dusturbd340W5] #438075
08/15/09 09:18 AM
08/15/09 09:18 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You are correct sir,The release levers turn the pump and the input is turned by the disc.With todays clutch technology you could make this into a highly consistent bracket transmission.Todays clutch setups take the "violent" out of the launch.
Gus
64 Plymouth Savoy
Dana 60
Re: So how did you race with a clutch flite? [Re: fourgearsavoy] #438076
08/15/09 01:39 PM
08/15/09 01:39 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I wish I had pictures of the one a good friend of mine blew up at the Halloween Classic 20 some years ago. It was in a high 8 second front engine dragster. It hit a guy in the grandstands about 20 rows up. Very dangerous combo.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: So how did you race with a clutch flite? [Re: Bob_Coomer] #438077
08/15/09 01:45 PM
08/15/09 01:45 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Launch procedure?
verrrrrry cafefully !!!!!!!
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: So how did you race with a clutch flite? [Re: SomeCarGuy] #438078
08/15/09 03:57 PM
08/15/09 03:57 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The originals were built with RMVB's but there's no reason one couldn't be built fully automatic...of course you'd have to run TP linkage/cable.
Re: So how did you race with a clutch flite? [Re: fourgearsavoy] #438079
08/15/09 08:28 PM
08/15/09 08:28 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Gus
You can use modern clutchs to soften the leave, but unless you shove in the clutch to shift, the lack of converter slippage makes for a very harsh shift. The ClutchFlights were a crutch for the lack of good converters in that era; now with converter tech what it is, a C/Flight is a novelty/gimmick and is more dangerous than usefull.
Re: So how did you race with a clutch flite? [Re: Evil Spirit] #438080
08/15/09 09:47 PM
08/15/09 09:47 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
I'm about to give the "poor mans lenco" a try. Of course it takes a ton of money (like Fred has) to make the thing even remotely safe. I have about 3k into it so far. 426 hemi, stack hilborn efi, 64 "ratcharger" polara. Clutchflite with a mcleod soft lok clutch, aa billet planet,lba valve body, billet drum, 16 element sprag.
MR2PERFORMANCE RACE CARS 765 483 9371
Re: So how did you race with a clutch flite? [Re: Evil Spirit] #438081
08/15/09 10:00 PM
08/15/09 10:00 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Don't forget the 2 trans blankies
Re: So how did you race with a clutch flite? [Re: Frito] #438082
08/15/09 10:03 PM
08/15/09 10:03 PM
USA
max Offline
super gas
max  Offline
super gas
USA
Launch procedure?
i'm sure Willard would know alot about them and he is a super nice guy to talk to.
when i spoke to him last year at Clay City he was talking about going with a Lenco but was having trouble getting the combo he wanted from the vendor.
that was also the same day they forgot to put the radiator cap on and water got under the slicks on the track and the car got loose and he scraped the wall with the rear of the car knocking the windup key off it.
here's a photo of the car that was taken about 2 years ago with the injectors still on it.
with the history and rarity behind that car it should be in a museum.
Re: So how did you race with a clutch flite? [Re: Bob_Coomer] #438083
08/15/09 10:14 PM
08/15/09 10:14 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Launch procedure?
PULL YOUR FEET WAY BACK......
Re: So how did you race with a clutch flite? [Re: max] #438084
08/16/09 10:22 PM
08/16/09 10:22 PM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
Willard, Ha. You DO know him. I don't think this is the Devin, but it is the car he had in Huntington eariler this year. I am trying to make a meet with him later this week.
Re: So how did you race with a clutch flite? [Re: max] #438085
08/26/09 04:43 AM
08/26/09 04:43 AM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
Max,
I spent several hours with Peanut yesterday, He is quite a character at 77!! You are right, he has a lot of info on this car and it should be in a museum!!!
