So how did you race with a clutch flite?
#438066
08/14/09 09:48 PM
08/14/09 09:48 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Seen one for sale in the classifieds. Burn out box procedure? Launch procedure? Just wondering, hate to sound dumb, but I dont know how it works. I assume you launch with a clutch, and shift as normal?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: So how did you race with a clutch flite?
[Re: Bob_Coomer]
#438068
08/14/09 10:47 PM
08/14/09 10:47 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Violently With no torque converter to cushion shifts they HAMMER the driveline. Not my idea of a street trans, and I sure wouldn't want to race one that didn't have bolt in sprag, good drums, etc. And 2 trans blankies
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Bob_Coomer]
#438069
08/15/09 12:43 AM
08/15/09 12:43 AM
Posts: 43,232 Bend,OR USA
Cab_Burge
burn outs like regular, start it in second and shift it into high Launch procedure, rev it to where you want to let the clutch out(the clutch drives the front pump now so there is no internal trans pressure until the clutch is released, it acts like like a stick set up ) and shift it at the RPM you want like a regular 3 speed automatic Real old technology, best left in the old days The new converters are way better now than back then, that is probally the main reason there(clutch type automatic trans.) no longer around or in use today
[Re: theraif]
#438071
08/15/09 01:16 AM
08/15/09 01:16 AM
Posts: 10,220 Someplace you aren't
SomeCarGuy
So can the trans shift on it's own or does it have to be manually shifted?
If I ever actually found one close to me, I had considered that putting one in my stick car might be kinda cool. But not if it cost a ton and was more likely to break stuff.
I want my fair share
[Re: Bob_Coomer]
#438073
08/15/09 06:17 AM
08/15/09 06:17 AM
Posts: 1,607 KYbywayof WV
Frito
KYbywayof WV
Bob, Peanut Stephens, (your neighbor) had one in a Devin sports car. It was equipped with a Hemi and injectors. He had the car at World of Wheels this year. The car has not been raced in over 30 years but he made a pass at Clay City last year. 426 Hemi with a NASCAR type bathtub intake and 4500 now insted of injectors. He lives between Greenup and Greenbow Lake. I will get his phone number for you.
[Re: Cab_Burge]
#438074
08/15/09 08:50 AM
08/15/09 08:50 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I believe the pressure plate drives the pump gears so the pump is always making pressure to keep the forward clutch applied and the input shaft is spline into the clutch disc that's what keeps the car from moving when clutch is pressed
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: fourgearsavoy]
#438076
08/15/09 01:39 PM
08/15/09 01:39 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I wish I had pictures of the one a good friend of mine blew up at the Halloween Classic 20 some years ago. It was in a high 8 second front engine dragster. It hit a guy in the grandstands about 20 rows up. Very dangerous combo.
[Re: Evil Spirit]
#438080
08/15/09 09:47 PM
08/15/09 09:47 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
I'm about to give the "poor mans lenco" a try. Of course it takes a ton of money (like Fred has) to make the thing even remotely safe. I have about 3k into it so far. 426 hemi, stack hilborn efi, 64 "ratcharger" polara. Clutchflite with a mcleod soft lok clutch, aa billet planet,lba valve body, billet drum, 16 element sprag.
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: Frito]
#438082
08/15/09 10:03 PM
08/15/09 10:03 PM
Posts: 2,648 USA
max
super gas
super gas
USA
i'm sure Willard would know alot about them and he is a super nice guy to talk to.
when i spoke to him last year at Clay City he was talking about going with a Lenco but was having trouble getting the combo he wanted from the vendor.
that was also the same day they forgot to put the radiator cap on and water got under the slicks on the track and the car got loose and he scraped the wall with the rear of the car knocking the windup key off it.
here's a photo of the car that was taken about 2 years ago with the injectors still on it.
with the history and rarity behind that car it should be in a museum.
[Re: Bob_Coomer]
#438083
08/15/09 10:14 PM
08/15/09 10:14 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
PULL YOUR FEET WAY BACK......
