Modifying Stock K-member #435651
08/12/09 03:14 PM
08/12/09 03:14 PM
The NB Vermont
dustaboy74 Offline OP
The NB Vermont
I was wondering what you guys did to your stock k-members and what you would recommend. Pictures would be great. I am currently building a 74 duster into a drag car and am looking for ideas to what to do with my stock k member. I will most likely becutting the motor mounts off and cutting the k member and boxing it but just wanted to see any other ideas that have worked well for others.
Re: Modifying Stock K-member [Re: dustaboy74] #435652
08/12/09 04:05 PM
08/12/09 04:05 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
Not a good picture, but I cut off the mounts and put a big notch for the oil pan. My buddy welded flat stock where the K was cut. This pic was when I yanked it all out to put the AlterKtion in...
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: Modifying Stock K-member [Re: BBLM23] #435653
08/12/09 04:13 PM
08/12/09 04:13 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Here is my current one. A few holes to lighten it, lip removed all the way around, reinforced keyhole slots to tie the car down. My last one had the motor mounts removed and notched and boxed for the oil pan.
I think one member cuts the whole center out and installs a piece of 2X3 as the cross piece.
Bondo Bob??
SRT DEMON ONE SEAT
Re: Modifying Stock K-member [Re: Ron Silva] #435654
08/12/09 04:14 PM
08/12/09 04:14 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
2
SRT DEMON ONE SEAT
Re: Modifying Stock K-member [Re: Ron Silva] #435655
08/12/09 05:05 PM
08/12/09 05:05 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Man nice work, but with a tig that had to take some time? Matt
Re: Modifying Stock K-member [Re: Ron Silva] #435656
08/12/09 09:20 PM
08/12/09 09:20 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Ron,I really like the slot idea for tie down point What did ya do in the rear?Did you weigh the "K" before & after??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Modifying Stock K-member [Re: dustaboy74] #435657
08/12/09 09:35 PM
08/12/09 09:35 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I used 1/8" x 4" flat stock, cut it out square, similar to the one pictured. If I would do it again I would cut it wider and deeper towards the front. Would make getting the pan off or even putting the engine in easier, deep pans suck. Make sure if you do decide to do surgery on the cross member either leave it bolted in the car or weld it to a heavy steel bench to keep it from warping.
Re: Modifying Stock K-member [Re: rowin4] #435658
08/12/09 09:41 PM
08/12/09 09:41 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I will be cutting off the mounts as I am going to a motor plate
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Modifying Stock K-member [Re: Kam*Kuda] #435659
08/12/09 09:43 PM
08/12/09 09:43 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Tubes added for strength
1654.5 Mustang
1955 Land Rover
Re: Modifying Stock K-member [Re: Kam*Kuda] #435660
08/12/09 10:21 PM
08/12/09 10:21 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Re: Modifying Stock K-member [Re: VernMotor] #435661
08/12/09 10:27 PM
08/12/09 10:27 PM
rowin4 Offline
rowin4  Offline
Thats were I would cut mine when I do it again, even with the steering box bracket and even with the idler bracket with a couple inches left at the front.
Re: Modifying Stock K-member [Re: rowin4] #435662
08/12/09 10:37 PM
08/12/09 10:37 PM
Truckville, the capital of NY
85_Ram_4speed Offline
Mine i did for my big block im my dartsport. Stock engine mounts cut off.
Outcast Dodge guy.
Re: Modifying Stock K-member [Re: 85_Ram_4speed] #435663
08/12/09 10:59 PM
08/12/09 10:59 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Mine is pretty much gone. The only part still original is the rear two ears that attach to the torsion bars.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Modifying Stock K-member [Re: DemonDust] #435664
08/12/09 11:32 PM
08/12/09 11:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
In the photo above, where do the strut rods attach? I think you have the right idea ... if you're going to start hacking away the k-member its easier to fab what you need rather than carve off what you don't need. You've given me some ideas !!
Re: Modifying Stock K-member [Re: Stanton] #435665
08/12/09 11:37 PM
08/12/09 11:37 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Strut rods?
Here is another angle, hope it helps.
SDG Motorsports
Re: Modifying Stock K-member [Re: DemonDust] #435666
08/12/09 11:42 PM
08/12/09 11:42 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Another angle, hope these help. If you are talking about the shock towers they are tied into the engine compartment roll bars.
SDG Motorsports
Re: Modifying Stock K-member [Re: DemonDust] #435667
08/13/09 02:26 AM
08/13/09 02:26 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
this is what happens when you have too much time on your hands in the off season.
Re: Modifying Stock K-member [Re: DemonDust] #435668
08/13/09 07:13 AM
08/13/09 07:13 AM
alabama
mopars rule Offline
mopar addict
mopars rule  Offline
mopar addict
alabama
I think they are referring to the rod running from the lower control arm to the K member to keep the LCA from flexing back and forth.
Re: Modifying Stock K-member [Re: rebel] #435669
08/13/09 11:55 AM
08/13/09 11:55 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Wait a Minute... The steerings on the wrong side... Looks good, but how is the pan clear...
Re: Modifying Stock K-member [Re: 70dusterjohn] #435670
08/13/09 02:21 PM
08/13/09 02:21 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
These are shots of my car,,,,work done by BondoBob,,,turned out awesome........
lost about 45 lbs,,,,,, and gained LOTS of clearance,,,,
