Re: Modifying Stock K-member
[Re: BBLM23]
#435653
08/12/09 04:13 PM
08/12/09 04:13 PM
Posts: 1,880 USA
Ron Silva
USA
Here is my current one. A few holes to lighten it, lip removed all the way around, reinforced keyhole slots to tie the car down. My last one had the motor mounts removed and notched and boxed for the oil pan.
I think one member cuts the whole center out and installs a piece of 2X3 as the cross piece.
Bondo Bob??
SRT DEMON ONE SEAT
[Re: dustaboy74]
#435657
08/12/09 09:35 PM
08/12/09 09:35 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I used 1/8" x 4" flat stock, cut it out square, similar to the one pictured. If I would do it again I would cut it wider and deeper towards the front. Would make getting the pan off or even putting the engine in easier, deep pans suck. Make sure if you do decide to do surgery on the cross member either leave it bolted in the car or weld it to a heavy steel bench to keep it from warping.
[Re: rowin4]
#435658
08/12/09 09:41 PM
08/12/09 09:41 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
I will be cutting off the mounts as I am going to a motor plate
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Kam*Kuda]
#435659
08/12/09 09:43 PM
08/12/09 09:43 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
Tubes added for strength
[Re: Stanton]
#435665
08/12/09 11:37 PM
08/12/09 11:37 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
In the photo above, where do the strut rods attach? I think you have the right idea ... if you're going to start hacking away the k-member its easier to fab what you need rather than carve off what you don't need. You've given me some ideas !!
Strut rods?
Here is another angle, hope it helps.
[Re: rebel]
#435669
08/13/09 11:55 AM
08/13/09 11:55 AM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
this is what happens when you have too much time on your hands in the off season.
Wait a Minute... The steerings on the wrong side... Looks good, but how is the pan clear...
[Re: 70dusterjohn]
#435670
08/13/09 02:21 PM
08/13/09 02:21 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
These are shots of my car,,,,work done by BondoBob,,,turned out awesome........ lost about 45 lbs,,,,,, and gained LOTS of clearance,,,,
[Re: 69CHARGERMD]
#435671
08/13/09 02:51 PM
08/13/09 02:51 PM
Posts: 10,022 MN
JERICOGTX
MN
Doug, now take the stock drag link back out and send it back to Bob, cut the center out, and weld in a CM tube. Saves another couple pounds... Bob's work looks VERY nice.
Jeff
69 GTX
68 Road Runner
[Re: JERICOGTX]
#435672
08/13/09 02:59 PM
08/13/09 02:59 PM
69CHARGERMD
KENTUCKY
Jeff, yup, he already did the drag link ,,,, and he did the steering shaft,,,,both are now CM... also,,cut off the old motor mounts,,,and made motor ears,,, he does great work,,, thinking of getting some of his tubular A arms soon,,,
[Re: dustaboy74]
#435673
08/13/09 03:06 PM
08/13/09 03:06 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
I was wondering what you guys did to your stock k-members and what you would recommend. Pictures would be great. I am currently building a 74 duster into a drag car and am looking for ideas to what to do with my stock k member. I will most likely becutting the motor mounts off and cutting the k member and boxing it but just wanted to see any other ideas that have worked well for others.
from the looks of it youve removed enough weight already!?!
[Re: 70dusterjohn]
#435676
08/13/09 05:56 PM
08/13/09 05:56 PM
Posts: 4,647 aotearoa
rebel
aotearoa
with all this room i made a special pan. the base is flush with the bottom of the K frame & holds 10 litres which i think is 12 quarts. no running out of oil for me. engine fitment is REAL easy.
