What are the advantages of adjust able rockers
#434469
08/10/09 11:52 PM
08/10/09 11:52 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
What are some of the advantage of having adjustable rockers over non adjustable stock iron rockers on a big block 440?
Mike
1969 Dodge Dart Swinger
Re: What are the advantages of adjust able rockers
[Re: MikeyT]
#434470
08/11/09 12:04 AM
08/11/09 12:04 AM
MikeyT
Watertown, WI
opps! Can someone move this into the unlawful race section thanx!
Mike
[Re: MikeyT]
#434471
08/11/09 12:20 AM
08/11/09 12:20 AM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Mike
I swapped to adjustable rockers on a 383 i had in the early 2000. We did it due to the large cam the PO had installed.
[Re: Just Cameron]
#434475
08/11/09 03:52 AM
08/11/09 03:52 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
You can screw up the preload and bend pushrods or wipe out a cam lobe?
Hey! Stop That!! He asked about Advantages... Not Disadvantages...
[Re: 1_WILD_RT]
#434476
08/11/09 07:44 AM
08/11/09 07:44 AM
MikeyT
Watertown, WI
Thanks guys, that makes sense it helps be consistent across the board in relation to preloads and such, does this trnaslate into any performance gains?
Mike
[Re: MikeyT]
#434477
08/11/09 09:50 AM
08/11/09 09:50 AM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
Thanks guys, that makes sense it helps be consistent across the board in relation to preloads and such, does this translate into any performance gains?
Mike
No not really , your stamped rockers will have the same preload consistency across the cylinder bank. But the adjustables will probably have a closer to 1.5 ratio over the stock stamped rockers so you'll get more performance that way . But just like when running a solid cam , which is why you need the adjustables , there has to be on 2 or 3 threads showing under the rocker. You need the CORRECT length pushrods , it's not going to be cheap to make the switch if you really don't need them .
