What are the advantages of adjust able rockers #434469
08/10/09 11:52 PM
08/10/09 11:52 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
What are some of the advantage of having adjustable rockers over non adjustable stock iron rockers on a big block 440?
Mike
1969 Dodge Dart Swinger
Re: What are the advantages of adjust able rockers [Re: MikeyT] #434470
08/11/09 12:04 AM
08/11/09 12:04 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
opps! Can someone move this into the unlawful race section thanx!
Mike
Re: What are the advantages of adjust able rockers [Re: MikeyT] #434471
08/11/09 12:20 AM
08/11/09 12:20 AM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
Mike
I swapped to adjustable rockers on a 383 i had in the early 2000. We did it due to the large cam the PO had installed.
Re: What are the advantages of adjust able rockers [Re: MikeyT] #434472
08/11/09 02:02 AM
08/11/09 02:02 AM
Southern California
Robert1050 Offline
stuck in da 70s
Robert1050  Offline
stuck in da 70s
Southern California
I went to them back in the late 70's on a 440-6 'cuda I owned, the previous owner had the heads milled and blocked decked big time to bump up the compression. I think it was around 10.5 to 1. I guess he just didn't want to buy custom pistons even back then. He had the pushrods shortened to compensate for the metal removal from the important components, but he used cheap pushrods, I tossed them after I bent to many of them and went to ISKY adjustables. End of problems. Besides, they looked cool whenever I pulled a valve-cover when some Mopar friends came over.
Re: What are the advantages of adjust able rockers [Re: Robert1050] #434473
08/11/09 03:43 AM
08/11/09 03:43 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
You can get consistent preload on all the rockers as well when running hyd lifters.
Re: What are the advantages of adjust able rockers [Re: RobX4406] #434474
08/11/09 03:49 AM
08/11/09 03:49 AM
Santa Rosa, NOR*CAL.
Just Cameron Offline
You can screw up the preload and bend pushrods or wipe out a cam lobe?
Re: What are the advantages of adjust able rockers [Re: Just Cameron] #434475
08/11/09 03:52 AM
08/11/09 03:52 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Hey! Stop That!! He asked about Advantages... Not Disadvantages...
Re: What are the advantages of adjust able rockers [Re: 1_WILD_RT] #434476
08/11/09 07:44 AM
08/11/09 07:44 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Thanks guys, that makes sense it helps be consistent across the board in relation to preloads and such, does this trnaslate into any performance gains?
Mike
Re: What are the advantages of adjust able rockers [Re: MikeyT] #434477
08/11/09 09:50 AM
08/11/09 09:50 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Thanks guys, that makes sense it helps be consistent across the board in relation to preloads and such, does this translate into any performance gains?
Mike
No not really , your stamped rockers will have the same preload consistency across the cylinder bank. But the adjustables will probably have a closer to 1.5 ratio over the stock stamped rockers so you'll get more performance that way . But just like when running a solid cam , which is why you need the adjustables , there has to be on 2 or 3 threads showing under the rocker. You need the CORRECT length pushrods , it's not going to be cheap to make the switch if you really don't need them .
