what sb manifold and carb makes the best power #434281
08/10/09 08:43 PM
08/10/09 08:43 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
for a 416, 9.7:1 comp, solid cam, 245/250 @ .050, ported TA heads, hooker super comps. makes good torque and power from 3000-6500. ive run a best of 10.2 in the 1000' with 4.30 gears but never been down the quarter mile
I have been playing with my sixpack manifold and carbs but want to try a 4bbl
so whats the hot ticket?
Re: what sb manifold and carb makes the best power [Re: aarcuda] #434282
08/10/09 08:45 PM
08/10/09 08:45 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Ported Victor 340 and a 950HP holley Carb
Re: what sb manifold and carb makes the best power [Re: aarcuda] #434283
08/10/09 11:01 PM
08/10/09 11:01 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Those OEM heads are killing your power. Get some Edelbrocks.
Re: what sb manifold and carb makes the best power [Re: aarcuda] #434284
08/11/09 12:36 AM
08/11/09 12:36 AM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
Super Victor with 950HP or 1000HP Holley
Re: what sb manifold and carb makes the best power [Re: qwkmopardan] #434285
08/11/09 02:12 AM
08/11/09 02:12 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Good combo there!
Re: what sb manifold and carb makes the best power [Re: RobX4406] #434286
08/11/09 02:30 AM
08/11/09 02:30 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
victor and a 950 on mine ported eddys, manifold is not ported
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: what sb manifold and carb makes the best power [Re: S/ST 3040] #434287
08/11/09 07:51 AM
08/11/09 07:51 AM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i dont know about that. they were ported pretty well by a well known small block guy named mullen. he did some fantastic work back in the mid to late 80's when i got them.
I always wanted to try a set of eddys but I just cant seem to jump into it.
heres a few pics. the ports had some surface rust on them from sitting for a few years.
Re: what sb manifold and carb makes the best power [Re: aarcuda] #434288
08/11/09 07:52 AM
08/11/09 07:52 AM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
again
Re: what sb manifold and carb makes the best power [Re: aarcuda] #434289
08/11/09 07:53 AM
08/11/09 07:53 AM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
and
Re: what sb manifold and carb makes the best power [Re: qwkmopardan] #434290
08/11/09 07:53 AM
08/11/09 07:53 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
the manifold at least seems to be a poor match for the rest of the combo (small solid, low compression)
I'd go eddie RPM air gap and the above carb. or maybe a thermoquad set up by demonsizzler.
2017 Grand Cherokee Overland
Re: what sb manifold and carb makes the best power [Re: aarcuda] #434291
08/11/09 08:27 AM
08/11/09 08:27 AM
S/ST 3040 Offline
S/ST 3040  Offline
aarcuda......I edited my post. Apparently nobody saw the humor in it.
patrick..........the RPM is a pretty decent manifold and would work
fine on a 416 but, a lot of guys miss the fact that a 416 requires
as much air to run 6140 RPM, as a 365 requires to run 7000 RPM.
Re: what sb manifold and carb makes the best power [Re: S/ST 3040] #434292
08/11/09 08:36 AM
08/11/09 08:36 AM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
gotcha!
Re: what sb manifold and carb makes the best power [Re: patrick] #434293
08/11/09 10:39 AM
08/11/09 10:39 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I think that it would be an interesting comparo with the Airgap and the Victor. My guess is the Victor would yield slightly better ET's but the Airgap would have better street manners. I know for a fact(dynos don't lie) that my 6 pak setup on my 416 cost me 39 HP as compared to an Airgap/950 combo.
Re: what sb manifold and carb makes the best power [Re: S/ST 3040] #434294
08/11/09 10:45 AM
08/11/09 10:45 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Check out this thread:
https://board.moparts.org/ubbthreads/show...e=1#Post5348972
The engine combo wasn't too far off yours, heads were ported W2's (intakes flowed in the 290's) but if Bob Mullins ported your 915's they probably flow pretty well. We saw a nice gain by going to the Holley 950.
Re: what sb manifold and carb makes the best power [Re: BobR] #434295
08/11/09 10:48 AM
08/11/09 10:48 AM
S/ST 3040 Offline
S/ST 3040  Offline
I also forgot to add......the 416 won't be nearly as sensitive to any reduced low
RPM torque, when switching from the long runner/dual plane, as the 340/360.
Re: what sb manifold and carb makes the best power [Re: BobR] #434296
08/11/09 10:55 AM
08/11/09 10:55 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Were it me, looking at the overall combo, i would go with a 950 as others have mentioned, and put a wieand excellerator under it. that intake has real solid street manners, and makes really good power at 6500 on a 416(i used to have that intake on my old 416 and went 10.70's with it on a heavy car with eddies and a flat tappet cam. That intake, IMO, is a perfect fiT for what you are doing, and they have another positive in that they generally line up perfectly when installing them, unlike most 340 victors i have seen,that require either bolt hole elongation, milling, or both to fit.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: what sb manifold and carb makes the best power [Re: S/ST 3040] #434297
08/11/09 11:01 AM
08/11/09 11:01 AM
Thats the first thing i'd do....
