Re: crankcase pressure/ blowing up valley pan
[Re: 440challenger]
#432726
08/09/09 05:18 PM
08/09/09 05:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
With 2 breathers I'm thinking he has broke some rings .... pull the breathers and run without them and see if the valley pan still bows up(push it down first)
[Re: 440challenger]
#432727
08/10/09 10:47 AM
08/10/09 10:47 AM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
he was having alot of problems with pinging up around 4500 + . I set the timing at 36 total with the heaviest msd springs in the pro billet distributor. It still pinged BAD. He talked to someone and the guy put the timing at 31 degrees total,does that seem right ??????/
Guessing he did some damage to the motor when he was trying to get rid of the ping
What was the INITIAL timing (with no centr. advance)? What color bushing is with the springs? Unless the the advance plate is LOCKED OUT you add initial + centrifical to get total timing. Did you check timing @ idle and then @ 3200 rpm? Don
[Re: MR_P_BODY]
#432728
08/10/09 11:05 AM
08/10/09 11:05 AM
Posts: 705 Michigan
Hemiroid
It's probably is wounded and is pinging because it's burning oil. Are the plugs oil fouled?
[Re: MR_P_BODY]
#432732
08/12/09 01:56 AM
08/12/09 01:56 AM
Posts: 202 CA
62SAVOY
CA
Is he running the breathers into the exhaust with the check valves? He may have had them go bad. I had it happen on my car. Street driven and bulged 2 pretty close back to back time frame. Took the breather hoses and went to free air. Been fine ever since. Mr. P Body did tell me in another post on this to check the check valves and the tubes that go into the exhaust to confirm there is no problems there.
[Re: qwkmopardan]
#432733
08/12/09 03:07 AM
08/12/09 03:07 AM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Put a nerf football between valleypan and bottom of intake and it will keep from inverting the valley pan.
A nerf football? ...
This gives the term "band-aid"(the words typically given to the iNfamous pinion-snubber) ... NEW meaning !! ...
[Re: 62SAVOY]
#432735
08/12/09 07:51 AM
08/12/09 07:51 AM
MR_P_BODY
Just for terminology, when a person says breathers I take that to be it is venting to atmosphere and if its hooked up to the exhaust I call that a evacuation system and in this case he stated breathers
[Re: emarine01]
#432736
08/12/09 12:25 PM
08/12/09 12:25 PM
dOoC
Florida STAYcation
I think proper cyl wall fiinish to ring choice is one of the hardest parts of engine building, done right makes major power done wrong makes for lots of blow by, I think thats what makes some builders combos run stronger than others with the same specs, Nerf football....?
OMG ....x2 ... x100 ...
[Re: dOoC]
#432737
08/12/09 06:30 PM
08/12/09 06:30 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
What is the rest of the engine? Heads, pistons, etc. 36° is a ton of timing for a long stroke big block. Ping can be an issue if too small a cam is used, and once the detonation starts, parts start to change shape. It destroys the rings and the ring lands in addition to blocks and bearings. Are there any pictures of the bores during assembly? It's not hard to see if it's too rough. Too rough means oil contamination in addition to larger ring gaps after they seat... lots of posibilities. Also, no reason to not run a pcv. which might have helped a little anyway.
