crankcase pressure/ blowing up valley pan #432720
08/09/09 04:30 PM
08/09/09 04:30 PM
NJ
440challenger Offline OP
NJ
A buddy of mine is running a 500ci with a roller cam,eddy heads. He's having a problem with the valley pan blowing up from crankcase pressure. He runs two K&n breathers with baffled valve covers. What would be some causes of bulding excessive pressure? No evac on this,just two breathers
Re: crankcase pressure/ blowing up valley pan [Re: 440challenger] #432721
08/09/09 04:36 PM
08/09/09 04:36 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Sounds to me like its time for a leak down test
Re: crankcase pressure/ blowing up valley pan [Re: 440challenger] #432722
08/09/09 04:37 PM
08/09/09 04:37 PM
Chicagoland
chargerron69 Offline
Chicagoland
lots of blow by. rings may not be sealing. i had a 400 that did that it inverted it against the manifold cracked from bending and oiled the engine compartment down. it would baloon to when you rev it. that was a loose motor. a pan evac may help depending on how bad it is. Do a leakdown test.
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: crankcase pressure/ blowing up valley pan [Re: chargerron69] #432723
08/09/09 04:42 PM
08/09/09 04:42 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i have a friend that sprayed his car at the track a few weeks ago. last weekend he noticed his valley pay bowed up and cracked.
he did a compression test and got 160 to 175. would he get good compression like that but still have blow by problems? he didnt do a leak down test yet- but we can
Re: crankcase pressure/ blowing up valley pan [Re: emarine01] #432724
08/09/09 04:56 PM
08/09/09 04:56 PM
NJ
NJ
he was having alot of problems with pinging up around 4500 + . I set the timing at 36 total with the heaviest msd springs in the pro billet distributor. It still pinged BAD. He talked to someone and the guy put the timing at 31 degrees total,does that seem right ??????/
Guessing he did some damage to the motor when he was trying to get rid of the ping
Re: crankcase pressure/ blowing up valley pan [Re: aarcuda] #432725
08/09/09 04:57 PM
08/09/09 04:57 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Compression testing and leak down are not the same in results, if the cyl is holding a lot of oil the cranking compression will still be high in a leak down the oil will blow back to the pan showing a ring seal problem,
Re: crankcase pressure/ blowing up valley pan [Re: 440challenger] #432726
08/09/09 05:18 PM
08/09/09 05:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With 2 breathers I'm thinking he has broke some rings
.... pull the breathers and run without them and see
if the valley pan still bows up(push it down first)
Re: crankcase pressure/ blowing up valley pan [Re: 440challenger] #432727
08/10/09 10:47 AM
08/10/09 10:47 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
What was the INITIAL timing (with no centr. advance)? What color bushing is with the springs?
Unless the the advance plate is LOCKED OUT you add initial + centrifical to get total timing.
Did you check timing @ idle and then @ 3200 rpm?
Don
Re: crankcase pressure/ blowing up valley pan [Re: MR_P_BODY] #432728
08/10/09 11:05 AM
08/10/09 11:05 AM
Hemiroid Offline
Hemiroid  Offline
It's probably is wounded and is pinging because it's burning oil. Are the plugs oil fouled?
Re: crankcase pressure/ blowing up valley pan [Re: Hemiroid] #432729
08/10/09 02:12 PM
08/10/09 02:12 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
This thing has some severe issues to do this ...
The last one I saw doing-this had a hole in the piston the size of a quarter.
It takes A LOT of blow-by to blow-up a valley pan.
Re: crankcase pressure/ blowing up valley pan [Re: dOoC] #432730
08/10/09 08:25 PM
08/10/09 08:25 PM
southwest Alabama
challenger73400 Offline
southwest Alabama
It doesn't take that much. I had one do this because I didn't have a pcv valve.
My race motor just did it but I don't know why yet. I have a breather in each valve cover. I ran it down the track like this and it ran dead on my dial in. Hope it's not hurt.
Re: crankcase pressure/ blowing up valley pan [Re: 440challenger] #432731
08/10/09 08:58 PM
08/10/09 08:58 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Detonation. What type of balancer. Outer ring might have slipped giving a false reading. Put a nerf football between valleypan and bottom of intake and it will keep from inverting the valley pan. Problem still needs to be solved and sounds like too much timing.
Re: crankcase pressure/ blowing up valley pan [Re: MR_P_BODY] #432732
08/12/09 01:56 AM
08/12/09 01:56 AM
CA
62SAVOY Offline
62SAVOY  Offline
CA
Is he running the breathers into the exhaust with the check valves? He may have had them go bad. I had it happen on my car. Street driven and bulged 2 pretty close back to back time frame. Took the breather hoses and went to free air. Been fine ever since. Mr. P Body did tell me in another post on this to check the check valves and the tubes that go into the exhaust to confirm there is no problems there.
Re: crankcase pressure/ blowing up valley pan [Re: qwkmopardan] #432733
08/12/09 03:07 AM
08/12/09 03:07 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
A nerf football? ...
This gives the term "band-aid"(the words typically given to the iNfamous pinion-snubber) ... NEW meaning !! ...
Re: crankcase pressure/ blowing up valley pan [Re: dOoC] #432734
08/12/09 07:37 AM
08/12/09 07:37 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I think proper cyl wall fiinish to ring choice is one of the hardest parts of engine building, done right makes major power done wrong makes for lots of blow by, I think thats what makes some builders combos run stronger than others with the same specs, Nerf football....?
Re: crankcase pressure/ blowing up valley pan [Re: 62SAVOY] #432735
08/12/09 07:51 AM
08/12/09 07:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just for terminology, when a person says breathers
I take that to be it is venting to atmosphere and
if its hooked up to the exhaust I call that a evacuation
system and in this case he stated breathers
Re: crankcase pressure/ blowing up valley pan [Re: emarine01] #432736
08/12/09 12:25 PM
08/12/09 12:25 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
OMG ....x2 ... x100 ...
Re: crankcase pressure/ blowing up valley pan [Re: dOoC] #432737
08/12/09 06:30 PM
08/12/09 06:30 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
What is the rest of the engine? Heads, pistons, etc. 36° is a ton of timing for a long stroke big block. Ping can be an issue if too small a cam is used, and once the detonation starts, parts start to change shape. It destroys the rings and the ring lands in addition to blocks and bearings. Are there any pictures of the bores during assembly? It's not hard to see if it's too rough. Too rough means oil contamination in addition to larger ring gaps after they seat... lots of posibilities. Also, no reason to not run a pcv. which might have helped a little anyway.
Re: crankcase pressure/ blowing up valley pan [Re: moper] #432738
08/12/09 07:37 PM
08/12/09 07:37 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I understand that it could be all of the issues mentioned above but I found out first hand it doesn't take a lot to destroy the valley pan. This picture of the valley pan I just removed. Yes that is a hole(crack). This was all due to my breather caps being to close to the valve cover baffle. They seemed ok but they were not. The engine was and still is running great. This has nothing to do with the pinging but swollen valley pan does not necessarily mean big problem.
Re: crankcase pressure/ blowing up valley pan [Re: mac56] #432739
08/12/09 08:08 PM
08/12/09 08:08 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Good point thats something I never thought about, my breather pipe nipple is kinda close to the baffle, we run a header evac so there is negative pressure helping relieve crankcase pressure but the amount of space in between the too can cause a bottle neck in the crankcase, I would think that rpm and cid would effect the space needed?
