Where to get a replacement 95 LeBaron window regulator #43179
07/03/07 11:34 AM
07/03/07 11:34 AM
SF Bay Area, CA
charger440sixpak Offline OP
SF Bay Area, CA
Rear pass. window on the 95 LeBaron conv. decided to go on strike this week...
Worm gear looks like a beaver's been snackin' & motor shaft is pretty corroded. I've found a couple places that look like they can repair or replace the regulator but I wanted to find out if anyone has dealt with them and if they do good work. Or maybe you can point me to an even better alternative.
Window Motor World, Inc in North Carolina ($125 + $10 S&H + $50 core)
Mirror Guard Co. in Brooklin, NY ($100 + $10 S&H + $40 core)
Any input would be appreciated, thanks!
Re: Where to get a replacement 95 LeBaron window regulator [Re: charger440sixpak] #43180
07/03/07 11:37 AM
07/03/07 11:37 AM
charlotte,nc
pyp1000 Offline
pyp1000  Offline
charlotte,nc
Don't know about any of these guys. I got my minivan motor and regulator from rockauto.com . Might wanna search there? Remember moparts has a discount code that you can use there.
Re: Where to get a replacement 95 LeBaron window regulator [Re: charger440sixpak] #43181
07/03/07 11:39 AM
07/03/07 11:39 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
Window Motor World, Inc is who i used for my 91 lebaron convertible. no problems.
Re: Where to get a replacement 95 LeBaron window regula [Re: 05dakota] #43182
04/21/09 09:10 PM
04/21/09 09:10 PM
SF Bay Area, CA
SF Bay Area, CA
Okay, I finally got an order into WMW and here's a picture of the motor they sent on the regulator. The wires are 16 or 18 gauge...
Re: Where to get a replacement 95 LeBaron window regula [Re: charger440sixpak] #43183
04/21/09 09:15 PM
04/21/09 09:15 PM
SF Bay Area, CA
SF Bay Area, CA
Now the original. I called the guy and he tells me I need to cut my wiring and connect the replacement. I was expecting to be able to connect the replacement using the original harness (which looks like 14 gauge wire).
Guy claimed he sells hundreds to pro installers (they all cut & modify the wiring) and nobody ever complained...
If you bought a replacement advertised for a Chrysler LeBaron rear pass. window regulator, am I being unreasonable to expect it have the correct connector? I need a sanity check...
Re: Where to get a replacement 95 LeBaron window regula [Re: charger440sixpak] #43184
04/22/09 12:01 AM
04/22/09 12:01 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I have four spares for our three LeBarons. They came from parts cars. I have also bought from the local self serve wrecking yards with good results.
The reason the motor corrodes is that it has been sitting in water because the rocker drains are plugged.
