Rear pass. window on the 95 LeBaron conv. decided to go on strike this week...
Worm gear looks like a beaver's been snackin' & motor shaft is pretty corroded. I've found a couple places that look like they can repair or replace the regulator but I wanted to find out if anyone has dealt with them and if they do good work. Or maybe you can point me to an even better alternative.
Window Motor World, Inc in North Carolina ($125 + $10 S&H + $50 core)
Mirror Guard Co. in Brooklin, NY ($100 + $10 S&H + $40 core)
Any input would be appreciated, thanks!
