EZ Heads #430005
08/06/09 02:14 PM
08/06/09 02:14 PM
SW PA
ctRT Offline OP
ctRT  Offline OP
SW PA
I have Indy EZ heads looking for a manifold to fit under a Challenger R/T hood. Will a MW manifold work with these heads?
Re: EZ Heads [Re: ctRT] #430006
08/06/09 02:46 PM
08/06/09 02:46 PM
AndyF Offline
AndyF  Offline
Are the heads max wedge or standard port size?
Re: EZ Heads [Re: AndyF] #430007
08/06/09 03:02 PM
08/06/09 03:02 PM
, PA
sleepyhead416 Offline
, PA
standard
Re: EZ Heads [Re: sleepyhead416] #430008
08/06/09 03:25 PM
08/06/09 03:25 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Mancini's sells a standard port cross ram
http://chucker54.stores.yahoo.net/manciniracing16.html
what do you intend to do with your car engine size cam ??
Re: EZ Heads [Re: ctRT] #430009
08/06/09 04:32 PM
08/06/09 04:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If its a standard port then any intake will do as long as its for that particular motor and meets your height requirement - like a plain old dual-plane.
The way I see it buying those heads in the standard configuration is just a waste of money - you may as well have just bought 440 source heads. The whole point is flow - hence the raised and enlarged port.
Re: EZ Heads [Re: ctRT] #430010
08/06/09 05:08 PM
08/06/09 05:08 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
I'm using a Holley SD on my std. port EZ's.
Re: EZ Heads [Re: Stanton] #430011
08/06/09 05:39 PM
08/06/09 05:39 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Yah, my 50 year old dual-plane, sixpack manifold fits under my shaker hood. Using a .550 lift hydraulic roller cam, the standard port EZ heads only flow enough to make 680 horsepower at 5500 rpm.
Re: EZ Heads [Re: jbc426] #430012
08/06/09 05:44 PM
08/06/09 05:44 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I'd run the INDY 2D dual plane on it, 5.25" tall, it comes in non max Wedge entrance & then they have a CNC MW gasket match option as well. That is manifold I run on my bowl blended EZ-1's..... Tons of TQ.
The 2D is much larger internally than a Performer RPM which would be my second choice.
Re: EZ Heads [Re: RyanJ] #430013
08/06/09 07:29 PM
08/06/09 07:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think you're full of crap !!! (or your dyno's broken !)
Re: EZ Heads [Re: RyanJ] #430014
08/06/09 07:41 PM
08/06/09 07:41 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i run four of them,and they will fit under any hood.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: EZ Heads [Re: Stanton] #430015
08/06/09 09:08 PM
08/06/09 09:08 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Don't be such a hater. The dyno wasn't broken, the numbers are strong, but no where near what is potentially still in there waiting to be found with further developement, testing and tuning.
These days, this kind of power is nothing unusual when the right combination of quality parts are put together by skilled hands.
Indy's regular port EZ heads are a great choice for those of us wanting to keep it under the hood, maintain high port velocities, and surprise some rube with numbers he thinks aren't possible with a 55-year-old intake design.
The results and dyno sheets can be seen at Hughes Engines...You can always argue with Dave or Kevin about their dyno....lol
http://www.hughesengines.com/TechArticles/13dynotest684hp500cid6pack4bbljcross012007.php
