Re: EZ Heads
[Re: Stanton]
#430011
08/06/09 05:39 PM
08/06/09 05:39 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
If its a standard port then any intake will do as long as its for that particular motor and meets your height requirement - like a plain old dual-plane.
The way I see it buying those heads in the standard configuration is just a waste of money - you may as well have just bought 440 source heads. The whole point is flow - hence the raised and enlarged port.
Yah, my 50 year old dual-plane, sixpack manifold fits under my shaker hood. Using a .550 lift hydraulic roller cam, the standard port EZ heads only flow enough to make 680 horsepower at 5500 rpm.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: EZ Heads
[Re: RyanJ]
#430013
08/06/09 07:29 PM
08/06/09 07:29 PM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I think you're full of crap !!! (or your dyno's broken !)
Re: EZ Heads
[Re: Stanton]
#430015
08/06/09 09:08 PM
08/06/09 09:08 PM
jbc426
West Coast, USA
Don't be such a hater. The dyno wasn't broken, the numbers are strong, but no where near what is potentially still in there waiting to be found with further developement, testing and tuning.
These days, this kind of power is nothing unusual when the right combination of quality parts are put together by skilled hands.
Indy's regular port EZ heads are a great choice for those of us wanting to keep it under the hood, maintain high port velocities, and surprise some rube with numbers he thinks aren't possible with a 55-year-old intake design.
The results and dyno sheets can be seen at Hughes Engines...You can always argue with Dave or Kevin about their dyno....lol http://www.hughesengines.com/TechArticles/13dynotest684hp500cid6pack4bbljcross012007.php
