hoosier slicks lifespan?? #429643
08/06/09 12:08 AM
08/06/09 12:08 AM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
so my 60' have gone away, how many passed do you get out of the hoosier slicks, i can still see the wear dots but i think the sidewalls are shot? i dont think that i have more than 50 passes on them but they are 2 years old
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: hoosier slicks lifespan?? [Re: Stroker Scamp] #429644
08/06/09 12:33 AM
08/06/09 12:33 AM
Renton Washington
Triple Threat Offline
Renton Washington
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: hoosier slicks lifespan?? [Re: Triple Threat] #429645
08/06/09 12:43 AM
08/06/09 12:43 AM
pacific northwest
pacific northwest
Burnout
http://www.youtube.com/watch?v=Vp8sQzFC7z8
Pass (terrible lighting)
http://www.youtube.com/watch?v=1k0V57gCkdw
yeah i get your point, i just couldnt get the thing to hook tonite 1.58 60' and had to get out of it once mid track,,,,,,,i am hoping that it was just the track, im second guessing getting new tires before pinks
Re: hoosier slicks lifespan?? [Re: Stroker Scamp] #429646
08/06/09 12:48 AM
08/06/09 12:48 AM
Renton Washington
Renton Washington
I haven't been to a Wednesday night yet this year, so I can't comment on the track prep.
Probably due for a set though, especially if the car sat on them for a winter or two.
-Dustin
Re: hoosier slicks lifespan?? [Re: Triple Threat] #429647
08/06/09 07:25 AM
08/06/09 07:25 AM
i get 38 to 40 and then the 60 foots get worse and worse, its not the track, its the hoosiers, soft compound.
both my 63 max wedge and 65 plymouth hemi just eat up hoosiers, i went back to M/T slicks and can go 100+ passes, same burnout.
Re: hoosier slicks lifespan?? [Re: Stroker Scamp] #429648
08/06/09 08:17 AM
08/06/09 08:17 AM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I dont think the wear holes matter much. My last set still had deep holes left but once I took them off the car I could see the cords showing. Depends on how fast your car is and how much you race but if they are over 2 years old they are due for replacing either way.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: hoosier slicks lifespan?? [Re: Stroker Scamp] #429649
08/06/09 09:09 AM
08/06/09 09:09 AM
NC
440Jim Offline
440Jim  Offline
NC
If the sixty foot is just slightly slower than before that is one thing, but if they are spinning, or sometimes spin sometimes hook; then the sidewalls may be worn out.
I was getting "low" slick life a fews years ago (90-110 passes), then I changed the chassis setup to hit the tire less, put wider rims on, added inner tubes, and this allowed me to increase air pressure 1-1.5 psi. Now I get 200 passes on my Phoenix slicks (31.25 x 12.2 W). So sometimes a setup change is the real answer.
What size tire are you running? A small tire on a heavy car with good power will be hard on slick life.
IMO, if you keep the slicks out of the sun between races and over the winter, and you don't let them sit on concrete, 2 years should not be a problem. After that the compound is getting older. During winter, the best method is to get the tires off the ground (no weight on them) and keep them out of the sun/weather. Concrete is bad for the compound.
Re: hoosier slicks lifespan?? [Re: Stroker Scamp] #429650
08/06/09 09:21 AM
08/06/09 09:21 AM
Central Coast
P
Plumcrazyracing Offline
P
Central Coast
Just one of the reasons why I went to M&H slicks.
www.mandhtires.com
Re: hoosier slicks lifespan?? [Re: Stroker Scamp] #429651
08/06/09 10:06 AM
08/06/09 10:06 AM
Kissimmee, Florida
aarlucas Offline
aarlucas  Offline
Kissimmee, Florida
I bought one set of Hoosier slicks and got 42 passes out of them before the 60' times started moving all over the map. I talked with a Hoosier rep at a national event and the first thing he asked me was how much did my car weight and what were the ET's. When I told him that info he said I killed the sidewalls with the weight and power I was making. He told me that if I was going to run the Hoosiers I needed to have a stiff side wall tire.
I ran a set of goodyears and they hooked until the thread was showing. Now I am trying a set of MT slicks and so far I have been happy with them, but I only have a few passes on them now.
