hoosier slicks lifespan??
#429643
08/06/09 12:08 AM
08/06/09 12:08 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
so my 60' have gone away, how many passed do you get out of the hoosier slicks, i can still see the wear dots but i think the sidewalls are shot? i dont think that i have more than 50 passes on them but they are 2 years old
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: hoosier slicks lifespan??
[Re: Triple Threat]
#429645
08/06/09 12:43 AM
08/06/09 12:43 AM
Stroker Scamp
pacific northwest
Burnout http://www.youtube.com/watch?v=Vp8sQzFC7z8
Pass (terrible lighting) http://www.youtube.com/watch?v=1k0V57gCkdw
yeah i get your point, i just couldnt get the thing to hook tonite 1.58 60' and had to get out of it once mid track,,,,,,,i am hoping that it was just the track, im second guessing getting new tires before pinks
[Re: Stroker Scamp]
#429646
08/06/09 12:48 AM
08/06/09 12:48 AM
Triple Threat
Renton Washington
I haven't been to a Wednesday night yet this year, so I can't comment on the track prep.
Probably due for a set though, especially if the car sat on them for a winter or two.
[Re: Triple Threat]
#429647
08/06/09 07:25 AM
08/06/09 07:25 AM
i get 38 to 40 and then the 60 foots get worse and worse, its not the track, its the hoosiers, soft compound. both my 63 max wedge and 65 plymouth hemi just eat up hoosiers, i went back to M/T slicks and can go 100+ passes, same burnout.
[Re: Stroker Scamp]
#429649
08/06/09 09:09 AM
08/06/09 09:09 AM
Posts: 16,928 NC
440Jim
NC
If the sixty foot is just slightly slower than before that is one thing, but if they are spinning, or sometimes spin sometimes hook; then the sidewalls may be worn out.
I was getting "low" slick life a fews years ago (90-110 passes), then I changed the chassis setup to hit the tire less, put wider rims on, added inner tubes, and this allowed me to increase air pressure 1-1.5 psi. Now I get 200 passes on my Phoenix slicks (31.25 x 12.2 W). So sometimes a setup change is the real answer.
What size tire are you running? A small tire on a heavy car with good power will be hard on slick life.
IMO, if you keep the slicks out of the sun between races and over the winter, and you don't let them sit on concrete, 2 years should not be a problem. After that the compound is getting older. During winter, the best method is to get the tires off the ground (no weight on them) and keep them out of the sun/weather. Concrete is bad for the compound.
[Re: Stroker Scamp]
#429650
08/06/09 09:21 AM
08/06/09 09:21 AM
Posts: 184 Central Coast
Plumcrazyracing
Central Coast
Just one of the reasons why I went to M&H slicks. www.mandhtires.com
