Build me a 9.90 small block
#429247
08/05/09 04:55 PM
08/05/09 04:55 PM
Posts: 465 Oconomowoc, WI.
Cudahlr
Oconomowoc, WI.
Looking to run 9.90 with a small block, im looking for input on engine combos, open to all your ideas, cid, procharger, turbo, nitrous, i still would like to drive short distances on the street every now and then. Car is a 68 barracuda #3000, 727 trans, 8 3/4 rear Thanks
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp 1985 Harley Sportster Bobber 2006 Ram 2500 sport - The Cudahlr
Re: Build me a 9.90 small block
[Re: Cudahlr]
#429249
08/05/09 05:33 PM
08/05/09 05:33 PM
Posts: 11,723 Portage,michigan
B3422W5
Portage,michigan
these days, to run 9.90 at that weight i would go with an indy cnc head and indy intake, a semi mild streetable roller, some compression that is mild enough to run 110 with (12.5 or so) and you are there.
my combo is w5's(likely not quite as good as a cnc indy head would be)a bit more agressive roller than what you could get away with, and an 8 inch convertor. i have been 9.85 at 3350 pounds, a good bit more weight than what you have to carry. I drive mine some on the street , but not a ton.
416 inch forged bottom end and the above indy topend end should get you there rather easily.
The key will be selecting a streetable roller lobe that will make enough power without real big spring pressures. mine is 270/ 590 spring pressures , and has given me no problems in 6 years. I suspect one step down in lobe type would be enough to get your car in the 9's rather easily...If i get a chance i will find out what lobe i have, fast 68 plymouth, who posts on here selected the lobe i use, and is extremely handy with cam selection.
Or you could run a flat tappet, less compression and pump gas, and sqirt it with a 125 shot to get there.
At 3000 pounds, its mighty easy to get a eddie headed 416 in the mid 10's without a lot of compression?(11.5-12 to 1)or a roller, and you could then sqirt that combo to get in the 9's rather easily.
[Re: TheOtherDodge]
#429251
08/05/09 05:50 PM
08/05/09 05:50 PM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
Since you didn't mention a budget, I would build a FI 400 inch Indy headed turbo.
maybee you can do the 9.90 with less head. w2,brodix, etc....f1-R3 will be way cool...
[Re: SB449VALIANT]
#429252
08/05/09 06:12 PM
08/05/09 06:12 PM
Posts: 1,880 USA
Ron Silva
USA
I plan on running 9.70 with a hydraulic roller cam, NA. I already sent Ryan a check to make sure that happens.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#429255
08/05/09 06:49 PM
08/05/09 06:49 PM
Posts: 2,637 Western Michigan
68Fastback
Western Michigan
Sorry to hi-jack the post but Ron what is Ryan building for the Valiant I assume.
[Re: Cudahlr]
#429256
08/05/09 07:18 PM
08/05/09 07:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
To be honest I would only run 10.0 if I had to set up again... its ALOT cheaper
[Re: MR_P_BODY]
#429257
08/05/09 07:28 PM
08/05/09 07:28 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
I agree with Mike. Chassis insp..$210..NHRA phys...$350 w/ekg...being able to run 9's...ah well take down that net and take your clothes off, run 10.00...PRICELESS!
The little old lady from Pasadena is back!
[Re: Barnstorm]
#429258
08/05/09 08:00 PM
08/05/09 08:00 PM
Posts: 1,880 USA
Ron Silva
USA
Here is what I suggest. But first. Is your car 3000 with you or by it's self? How much do you weigh? Anyhow, you did not give a budget. I like NA, so it's a R3 9.56 deck siamese 4.185 bore 11:1 compression with a callies 4.25 stroke crank, Indy -1 245 CNC heads/manifold and a good roller cam and you are set. Plus some good headers / ign and carb.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#429259
08/05/09 09:12 PM
08/05/09 09:12 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Humm... The choices.
Assuming the car works...
If you want durability for years and years to come start with an R3 block, 408-425" with good internals, Ported Eddies, 360-2's, CNC'ed, doesnt really matter, your choice... Solid lifter cam around 240 @ .050, 600 lift, 750 DP...
BW S400 (75 or 80mm) with 12 lbs of boost on pump gas = Game Over.
Turn the boost up, add race gas, and go 8's.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#429260
08/05/09 09:45 PM
08/05/09 09:45 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
I went 9.40's with my smallblock on pumpgas-14-15psi...5.60's with racegas in the 1/8th-24-25psi. Sure cost a whole lot to get there and definetly not for the faint of heart. Definetly not the cheapest way to get those kind of times, but I have enjoyed every minute...well atleast most every minute. 408ci Mopar Resto-block Edelbrock heads Twin 61mm turbos http://www.youtube.com/watch?v=1NJeUG2mpVA
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: instigator]
#429261
08/05/09 10:04 PM
08/05/09 10:04 PM
Cudahlr
Oconomowoc, WI.
The reason for 9.90 is because a friend of mine says it cant be done, so I see a challenge, and its time to step it up a bit anyways, my current combo is feeling kinda slow lately. Also I forgot about my weight, so the total weight with me would be #3160 What I kinda had in mind was a 408" - 416" block, I have a '69 340 block and a '70 360 block also a r-3 block would not be out of the question if needed, Indy 360-1 cnc heads and intake, 950cfm holley, solid roller cam, TTI headers, rods and crank im still undecided. I also can get a procharger setup from a friend at a good price. Lets here some more ideas,Thanks
[Re: Cudahlr]
#429262
08/05/09 10:30 PM
08/05/09 10:30 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
You don't need a power adder to run 9.90 with a small block. A good set of heads with a strong bottom end will get it done.
[Re: PUNK]
#429264
08/05/09 11:48 PM
08/05/09 11:48 PM
Posts: 20,843 A collage of whims
topside
A collage of whims
Invest in an R block, much stronger webs & pan rail than the stock 340/360 blocks. I'm hoping to card a 9.90-something with 368" in my 3000lb footbrake Duster myself. Combo's fairly basic & posted on my "toy" website, http://topside.info.Then, after I get thrown out, the plan is to just run low 10s so I don't have to jump through the 9.90 hoops...
[Re: Leon441]
#429266
08/06/09 12:22 AM
08/06/09 12:22 AM
topfueldart
Renton Wa
Not "needed" no... but you'll save probably $1500 not needing a .700 solid roller and T&D's or Jesel's... And you wont need race gas if setup correctly, or to spin it to 7500.... And it will be much more street friendly if thats a concern.
And it'll be alot easier to step up the numbers down the road.
Everyone has preferences, there are more than 2 ways to skin a cat...
