Build me a 9.90 small block
#429247
08/05/09 04:55 PM
08/05/09 04:55 PM
Posts: 465 Oconomowoc, WI.
Cudahlr
Oconomowoc, WI.
Looking to run 9.90 with a small block, im looking for input on engine combos, open to all your ideas, cid, procharger, turbo, nitrous, i still would like to drive short distances on the street every now and then. Car is a 68 barracuda #3000, 727 trans, 8 3/4 rear Thanks
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp 1985 Harley Sportster Bobber 2006 Ram 2500 sport - The Cudahlr
Re: Build me a 9.90 small block
[Re: Cudahlr]
#429249
08/05/09 05:33 PM
08/05/09 05:33 PM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
these days, to run 9.90 at that weight i would go with an indy cnc head and indy intake, a semi mild streetable roller, some compression that is mild enough to run 110 with (12.5 or so) and you are there.
my combo is w5's(likely not quite as good as a cnc indy head would be)a bit more agressive roller than what you could get away with, and an 8 inch convertor. i have been 9.85 at 3350 pounds, a good bit more weight than what you have to carry. I drive mine some on the street , but not a ton.
416 inch forged bottom end and the above indy topend end should get you there rather easily.
The key will be selecting a streetable roller lobe that will make enough power without real big spring pressures. mine is 270/ 590 spring pressures , and has given me no problems in 6 years. I suspect one step down in lobe type would be enough to get your car in the 9's rather easily...If i get a chance i will find out what lobe i have, fast 68 plymouth, who posts on here selected the lobe i use, and is extremely handy with cam selection.
Or you could run a flat tappet, less compression and pump gas, and sqirt it with a 125 shot to get there.
At 3000 pounds, its mighty easy to get a eddie headed 416 in the mid 10's without a lot of compression?(11.5-12 to 1)or a roller, and you could then sqirt that combo to get in the 9's rather easily.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: TheOtherDodge]
#429251
08/05/09 05:50 PM
08/05/09 05:50 PM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
Since you didn't mention a budget, I would build a FI 400 inch Indy headed turbo.
maybee you can do the 9.90 with less head. w2,brodix, etc....f1-R3 will be way cool...
[Re: SB449VALIANT]
#429252
08/05/09 06:12 PM
08/05/09 06:12 PM
Posts: 1,880 USA
Ron Silva
USA
I plan on running 9.70 with a hydraulic roller cam, NA. I already sent Ryan a check to make sure that happens.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#429255
08/05/09 06:49 PM
08/05/09 06:49 PM
Posts: 2,637 Western Michigan
68Fastback
Western Michigan
Sorry to hi-jack the post but Ron what is Ryan building for the Valiant I assume.
[Re: Cudahlr]
#429256
08/05/09 07:18 PM
08/05/09 07:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
To be honest I would only run 10.0 if I had to set up again... its ALOT cheaper
[Re: MR_P_BODY]
#429257
08/05/09 07:28 PM
08/05/09 07:28 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
I agree with Mike. Chassis insp..$210..NHRA phys...$350 w/ekg...being able to run 9's...ah well take down that net and take your clothes off, run 10.00...PRICELESS!
The little old lady from Pasadena is back!
[Re: Barnstorm]
#429258
08/05/09 08:00 PM
08/05/09 08:00 PM
Posts: 1,880 USA
Ron Silva
USA
Here is what I suggest. But first. Is your car 3000 with you or by it's self? How much do you weigh? Anyhow, you did not give a budget. I like NA, so it's a R3 9.56 deck siamese 4.185 bore 11:1 compression with a callies 4.25 stroke crank, Indy -1 245 CNC heads/manifold and a good roller cam and you are set. Plus some good headers / ign and carb.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#429259
08/05/09 09:12 PM
08/05/09 09:12 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Humm... The choices.
Assuming the car works...
If you want durability for years and years to come start with an R3 block, 408-425" with good internals, Ported Eddies, 360-2's, CNC'ed, doesnt really matter, your choice... Solid lifter cam around 240 @ .050, 600 lift, 750 DP...
BW S400 (75 or 80mm) with 12 lbs of boost on pump gas = Game Over.
Turn the boost up, add race gas, and go 8's.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#429260
08/05/09 09:45 PM
08/05/09 09:45 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
I went 9.40's with my smallblock on pumpgas-14-15psi...5.60's with racegas in the 1/8th-24-25psi. Sure cost a whole lot to get there and definetly not for the faint of heart. Definetly not the cheapest way to get those kind of times, but I have enjoyed every minute...well atleast most every minute. 408ci Mopar Resto-block Edelbrock heads Twin 61mm turbos http://www.youtube.com/watch?v=1NJeUG2mpVA
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: instigator]
#429261
08/05/09 10:04 PM
08/05/09 10:04 PM
Cudahlr
Oconomowoc, WI.
The reason for 9.90 is because a friend of mine says it cant be done, so I see a challenge, and its time to step it up a bit anyways, my current combo is feeling kinda slow lately. Also I forgot about my weight, so the total weight with me would be #3160 What I kinda had in mind was a 408" - 416" block, I have a '69 340 block and a '70 360 block also a r-3 block would not be out of the question if needed, Indy 360-1 cnc heads and intake, 950cfm holley, solid roller cam, TTI headers, rods and crank im still undecided. I also can get a procharger setup from a friend at a good price. Lets here some more ideas,Thanks
[Re: Cudahlr]
#429262
08/05/09 10:30 PM
08/05/09 10:30 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
You don't need a power adder to run 9.90 with a small block. A good set of heads with a strong bottom end will get it done.
[Re: PUNK]
#429264
08/05/09 11:48 PM
08/05/09 11:48 PM
Posts: 20,826 A collage of whims
topside
A collage of whims
Invest in an R block, much stronger webs & pan rail than the stock 340/360 blocks. I'm hoping to card a 9.90-something with 368" in my 3000lb footbrake Duster myself. Combo's fairly basic & posted on my "toy" website, http://topside.info.Then, after I get thrown out, the plan is to just run low 10s so I don't have to jump through the 9.90 hoops...
[Re: Leon441]
#429266
08/06/09 12:22 AM
08/06/09 12:22 AM
topfueldart
Renton Wa
Not "needed" no... but you'll save probably $1500 not needing a .700 solid roller and T&D's or Jesel's... And you wont need race gas if setup correctly, or to spin it to 7500.... And it will be much more street friendly if thats a concern.
And it'll be alot easier to step up the numbers down the road.
Everyone has preferences, there are more than 2 ways to skin a cat...
