Welding brace on 8 3/4, without a jig
#428117
08/04/09 09:49 AM
08/04/09 09:49 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Is it mandatory to have your housing in a jig when welding a brace?
Have any of you put a brace on without a jig and it not come out warped? I'll stitch it, let it cool, etc.
Better to have the rearend together when welding the brace on?
Any tips to help with the process?
Thanks in advance for any help.
PS, yeah I know the 8 3/4 is junk, dont need to get into that discussion.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Welding brace on 8 3/4, without a jig
[Re: scratchnfotraction]
#428119
08/04/09 12:43 PM
08/04/09 12:43 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
It definitely will move, I don't care how you weld it, weld it on then check it with an alignment bar, if crooked cut 0ff ends and reweld Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: mr2performance]
#428120
08/04/09 12:50 PM
08/04/09 12:50 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
I have welded them on with the center in, no gears or bearings in it, just the center, I then used a chain, or come along and use it like a truss, put tension on it in the oposite direction the housing will flex, and you chould be fine. Mine moved only less than a 32nd of an inch. I welded it completely, and let it self cool, dont quench it, just let it stand. Should be ok, but I would definatly check it after it has cooled, and you take the truss off.
Kasey
#428122
08/04/09 03:51 PM
08/04/09 03:51 PM
Quicktree
thats for sure the right way to do it. but I have welded them with the axels and center section in. was a low HP bracket car grant you. but it worked more than once and is still working. I am sure if we pulled it down and checked it with a jig it would be out. but the axels still slide in easy and the rear makes no noise. I tack them, then go back and weld very small areas and let them cool. on a street car or low HP you can get away with it. if it was a high HP car you probably wouldn't be using an 83/4 anyway ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: jcc]
#428124
08/06/09 08:34 PM
08/06/09 08:34 PM
Posts: 64 Airville Pa.
boomer
Airville Pa.
Also tap each weld with a slag hammer to relieve it as it cools and it will not pull.....
[Re: boomer]
#428125
08/06/09 10:42 PM
08/06/09 10:42 PM
Posts: 6,150 Melbourne , Australia
LA360
Some take short cuts and get away with, most don't. Have it done properly and save yourself headaches in the long run. AL....
Alan Jones
[Re: Von]
#428126
08/06/09 10:58 PM
08/06/09 10:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've welded a few back braces on, if you do short welds jumping around so you dont heat it too much it works fine... if your going to shorten the housing, put the ends on last.... JMO ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Von]
#428127
08/07/09 12:32 AM
08/07/09 12:32 AM
Thumperdart
State of confusion
I had my friend do mine and he used a jig and his welds look flawless.......if that matters. How much can it really cost to do it right and leave out the guess work?
[Re: Thumperdart]
#428128
08/07/09 08:55 AM
08/07/09 08:55 AM
MR_P_BODY
I have a alignment bar also and if it needs it I put it in my press to tweak it. After I measure the flanges with a straight edge attached to see if the flanges are parallel to each other ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Von]
#428131
08/07/09 12:53 PM
08/07/09 12:53 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
I don't think having a jig installed when welding on a backbrace will do anything. The welding puts stress in the housing whether a jig is involved or not. Stitch welding it and moving around a lot with lots of cooling time minimizes the stress. Or burn it on there and weld the ends on last.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
