Welding brace on 8 3/4, without a jig #428117
08/04/09 09:49 AM
08/04/09 09:49 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Is it mandatory to have your housing in a jig when welding a brace?
Have any of you put a brace on without a jig and it not come out warped? I'll stitch it, let it cool, etc.
Better to have the rearend together when welding the brace on?
Any tips to help with the process?
Thanks in advance for any help.
PS, yeah I know the 8 3/4 is junk, dont need to get into that discussion.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Welding brace on 8 3/4, without a jig [Re: Von] #428118
08/04/09 10:16 AM
08/04/09 10:16 AM
scratchnfotraction Offline
Re: Welding brace on 8 3/4, without a jig [Re: scratchnfotraction] #428119
08/04/09 12:43 PM
08/04/09 12:43 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
It definitely will move, I don't care how you weld it, weld it on then check it with an alignment bar, if crooked cut 0ff ends and reweld Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: Welding brace on 8 3/4, without a jig [Re: mr2performance] #428120
08/04/09 12:50 PM
08/04/09 12:50 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I have welded them on with the center in, no gears or bearings in it, just the center, I then used a chain, or come along and use it like a truss, put tension on it in the oposite direction the housing will flex, and you chould be fine. Mine moved only less than a 32nd of an inch. I welded it completely, and let it self cool, dont quench it, just let it stand. Should be ok, but I would definatly check it after it has cooled, and you take the truss off.
Kasey
Re: Welding brace on 8 3/4, without a jig [Re: Von] #428121
08/04/09 02:25 PM
08/04/09 02:25 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A simple brace would be easy enough to build ...
A large enough piece of I-beam from a scrap metal place. Set the housing face down on it. Use U-bolts on either end to cinch down the ends. Probably wouldn't hurt to even put a 1/16" preload on each end !!
Re: Welding brace on 8 3/4, without a jig [Re: mr2performance] #428122
08/04/09 03:51 PM
08/04/09 03:51 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats for sure the right way to do it. but I have welded them with the axels and center section in. was a low HP bracket car grant you. but it worked more than once and is still working. I am sure if we pulled it down and checked it with a jig it would be out.
but the axels still slide in easy and the rear makes no noise. I tack them, then go back and weld very small areas and let them cool. on a street car or low HP you can get away with it. if it was a high HP car you probably wouldn't be using an 83/4 anyway
Re: Welding brace on 8 3/4, without a jig [Re: Quicktree] #428123
08/05/09 10:04 PM
08/05/09 10:04 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Re: Welding brace on 8 3/4, without a jig [Re: jcc] #428124
08/06/09 08:34 PM
08/06/09 08:34 PM
Airville Pa.
boomer Offline
boomer  Offline
Airville Pa.
Also tap each weld with a slag hammer to relieve it as it cools and it will not pull.....
Re: Welding brace on 8 3/4, without a jig [Re: boomer] #428125
08/06/09 10:42 PM
08/06/09 10:42 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Some take short cuts and get away with, most don't. Have it done properly and save yourself headaches in the long run.
AL....
Alan Jones
Re: Welding brace on 8 3/4, without a jig [Re: Von] #428126
08/06/09 10:58 PM
08/06/09 10:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've welded a few back braces on, if you do short welds
jumping around so you dont heat it too much it works
fine... if your going to shorten the housing, put the
ends on last.... JMO
Re: Welding brace on 8 3/4, without a jig [Re: Von] #428127
08/07/09 12:32 AM
08/07/09 12:32 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I had my friend do mine and he used a jig and his welds look flawless.......if that matters. How much can it really cost to do it right and leave out the guess work?
Re: Welding brace on 8 3/4, without a jig [Re: Thumperdart] #428128
08/07/09 08:55 AM
08/07/09 08:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a alignment bar also and if it needs it I put
it in my press to tweak it. After I measure the flanges
with a straight edge attached to see if the flanges are
parallel to each other
Re: Welding brace on 8 3/4, without a jig [Re: MR_P_BODY] #428129
08/07/09 09:08 AM
08/07/09 09:08 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
I welded mine assembled in the car and when i changed the axles everything slid in & out fine.That's all that matters for me.Took my time welding and didn't allow any heat to build up.Maybe I'm just lucky? Now transmissions not so lucky
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Welding brace on 8 3/4, without a jig [Re: Von] #428130
08/07/09 12:04 PM
08/07/09 12:04 PM
Start by welding one inch on the top of one side and then switch to the other side and do a inch on the bottom side of the brace, alternate back and forth. Take your time and take a few breaks to let it cool so you don't get a bunh of heat on one side, top or bottom Having a jig is the best way but a guy has to do what he has to do with, in most cases
Re: Welding brace on 8 3/4, without a jig [Re: Von] #428131
08/07/09 12:53 PM
08/07/09 12:53 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
I don't think having a jig installed when welding on a backbrace will do anything. The welding puts stress in the housing whether a jig is involved or not. Stitch welding it and moving around a lot with lots of cooling time minimizes the stress. Or burn it on there and weld the ends on last.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
