68 b body backup light harness/nss #422125
07/28/09 07:52 PM
07/28/09 07:52 PM
NJ
440challenger Offline OP
NJ
68 road runner. currently have an auto trans and no nss/backup light harness in the car. I was trying to find in yearone catalog, and all i found was a nss wire/looks like a single wire? I have a 3 prong nss on my trans. Can anyone tell me where the harness plugs into so i have reverse lights and so i can elimate my nss jumper wire i made. Thanks!!!!!!!
Re: 68 b body backup light harness/nss [Re: 440challenger] #422126
07/28/09 08:05 PM
07/28/09 08:05 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I don't know if the aftermarket makes the 2 prong rubber end that will go on the trans switch, you may have to make one. You can splice it into bulkhead connector cleanly. You just need a wiring diagram for the 68 b body. I converted my 68 coro back and forth from auto to stick and even had the dash reverse lamp working for the automatic also. No hacking was required.
Re: 68 b body backup light harness/nss [Re: buildanother] #422127
07/28/09 09:18 PM
07/28/09 09:18 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
The back up light switch on my column shifted 68 rr is on the column, not in the trans like the newer ones. You probably already have a plug under the dash for it near the column.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: 68 b body backup light harness/nss [Re: johnedod] #422128
07/28/09 09:28 PM
07/28/09 09:28 PM
NJ
NJ
My car is a 4spd car ....Is there a plug under the dash? If i plugged the harness into the NSS,how would the harness route?
Re: 68 b body backup light harness/nss [Re: 440challenger] #422129
07/28/09 09:48 PM
07/28/09 09:48 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
Sorry, I wouldn't know if the same plug would be there on a factory 4 speed car or not. And I don't have a parts car to check either. If you had a factory 4 speed harness you could just cut it and splice it into the 2 outer wires on your 3 prong switch on the trans. Then run the middle prong up to the starter relay for the nss. But I don't know how these wires were factory routed. Sorry maybe some body else will chime in....
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: 68 b body backup light harness/nss [Re: 440challenger] #422130
07/29/09 09:09 AM
07/29/09 09:09 AM
NJ
NJ
It looks like the reverse light wires are violet in color . If i have a floor shift car, should their be a plug under the dash?, that you could plug a nss harness in from the NSS on the trans to the plug ?
Re: 68 b body backup light harness/nss [Re: 440challenger] #422131
07/29/09 09:35 AM
07/29/09 09:35 AM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
If I were you I think I'd just get some new wire and make a b/up light-nss harness. Take a plug that fits your 3 prong switch on the trans and wire the 2 outer prongs for the lights and the center prong for the starter relay. Wrap it all in black tape. The factory routing would likely be up the trans tunnel and you could put a metal tab on one of the top bell housing bolts to fasten the harness to. Then run it up the firewall to where your engine harness comes across and run it thru those clips. Run the center wire to your starter relay. Run the other 2 thru the firewall either thru some empty holes in your bulk head connector or since it's originally a stick car you could go thru the hole your clutch linkage used to go thru. If the original 2 wire plug for your b up lights is there it should be near the bottom of the column. Yes I THINK the wires are violet. If you can't find the original wires just run one to key on power and the other to the wire in the drivers side kick panel that that runs to the back up lights which I think is violet.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: 68 b body backup light harness/nss [Re: 440challenger] #422132
07/29/09 09:50 AM
07/29/09 09:50 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
On a 68, there is no neutral switch feature. If you look at the starter relay, there is a tab welded from the case to the pin where the switch would ground to. On the transmission, there should just be a reverse light switch on the tranmisssion (two flat blade terminals). The under dash harness feeds the voltage through one leg to the bulkhead disconnect, then to the switch on the transmission, then back up to complete the circuit through another terminal in the disconnect. From there it splits to the rear light harness and to the under dash reverse indicator. A wiring diagram can show it 100 times better than I can explain.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 68 b body backup light harness/nss [Re: RoadRunner] #422133
07/29/09 11:43 AM
07/29/09 11:43 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Can you wire one of these into your harness? Then use a starter solinoid that has a NSS feature?
http://www.yearone.com/serverfiles/fbshopmain2.asp?cat=1
Mopar A/B/E Bodies » Electrical » Harnesses - Backup Light » B-Body » HU232N
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 68 b body backup light harness/nss [Re: HealthServices] #422134
07/29/09 12:27 PM
07/29/09 12:27 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
There ya go! Problem solved!
And road runner is right, my starter relay doesn't have a terminal for a nss. But in your previous posts you seemed to really want to use one so I was assuming the relay on your car had one. Anyway it seems that harness that health services posted would be a great fix for you.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: 68 b body backup light harness/nss [Re: johnedod] #422135
07/29/09 01:45 PM
07/29/09 01:45 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
You can get a starter relay with the NSS prong for an automatic car. A 68 Should have a 1 prong NSS switch on the trans, and the reverse lights are activated on top of the column, under the dash.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
