Re: 68 b body backup light harness/nss
[Re: buildanother]
#422127
07/28/09 09:18 PM
07/28/09 09:18 PM
Posts: 601 Clintwood VA
johnedod
Clintwood VA
The back up light switch on my column shifted 68 rr is on the column, not in the trans like the newer ones. You probably already have a plug under the dash for it near the column.
Johnedod 68 Road Runner 71 Road Runner 78 Power Wagon
[Re: 440challenger]
#422129
07/28/09 09:48 PM
07/28/09 09:48 PM
johnedod
Clintwood VA
Sorry, I wouldn't know if the same plug would be there on a factory 4 speed car or not. And I don't have a parts car to check either. If you had a factory 4 speed harness you could just cut it and splice it into the 2 outer wires on your 3 prong switch on the trans. Then run the middle prong up to the starter relay for the nss. But I don't know how these wires were factory routed. Sorry maybe some body else will chime in....
[Re: 440challenger]
#422131
07/29/09 09:35 AM
07/29/09 09:35 AM
johnedod
Clintwood VA
If I were you I think I'd just get some new wire and make a b/up light-nss harness. Take a plug that fits your 3 prong switch on the trans and wire the 2 outer prongs for the lights and the center prong for the starter relay. Wrap it all in black tape. The factory routing would likely be up the trans tunnel and you could put a metal tab on one of the top bell housing bolts to fasten the harness to. Then run it up the firewall to where your engine harness comes across and run it thru those clips. Run the center wire to your starter relay. Run the other 2 thru the firewall either thru some empty holes in your bulk head connector or since it's originally a stick car you could go thru the hole your clutch linkage used to go thru. If the original 2 wire plug for your b up lights is there it should be near the bottom of the column. Yes I THINK the wires are violet. If you can't find the original wires just run one to key on power and the other to the wire in the drivers side kick panel that that runs to the back up lights which I think is violet.
[Re: 440challenger]
#422132
07/29/09 09:50 AM
07/29/09 09:50 AM
Posts: 5,140 East Aurora (Buffalo) NY
RoadRunner
On a 68, there is no neutral switch feature. If you look at the starter relay, there is a tab welded from the case to the pin where the switch would ground to. On the transmission, there should just be a reverse light switch on the tranmisssion (two flat blade terminals). The under dash harness feeds the voltage through one leg to the bulkhead disconnect, then to the switch on the transmission, then back up to complete the circuit through another terminal in the disconnect. From there it splits to the rear light harness and to the under dash reverse indicator. A wiring diagram can show it 100 times better than I can explain.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#422133
07/29/09 11:43 AM
07/29/09 11:43 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Can you wire one of these into your harness? Then use a starter solinoid that has a NSS feature? http://www.yearone.com/serverfiles/fbshopmain2.asp?cat=1Mopar A/B/E Bodies » Electrical » Harnesses - Backup Light » B-Body » HU232N ![](http://www.yearone.com/images/parts/ha_hz/hu232n.jpg)
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#422134
07/29/09 12:27 PM
07/29/09 12:27 PM
johnedod
Clintwood VA
There ya go! Problem solved! ![](/ubbthreads/images/graemlins/thumbs.gif) And road runner is right, my starter relay doesn't have a terminal for a nss. But in your previous posts you seemed to really want to use one so I was assuming the relay on your car had one. Anyway it seems that harness that health services posted would be a great fix for you.
[Re: johnedod]
#422135
07/29/09 01:45 PM
07/29/09 01:45 PM
Posts: 849 Avondale AZ
Prodart440
Avondale AZ
You can get a starter relay with the NSS prong for an automatic car. A 68 Should have a 1 prong NSS switch on the trans, and the reverse lights are activated on top of the column, under the dash.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
