Oil Warning light #386707
07/26/09 11:47 AM
07/26/09 11:47 AM
Way North Illinois
JandJ_Racing Offline OP
Way North Illinois
Anyone know a part number for the Auto Meter oil warning light to turn on at 20 psi and screw into an 1/8" pipe thread?? I know Summit has it from Rebco but I was told NAPA would have it but I have called three stores with no luck.
Re: Oil Warning light [Re: JandJ_Racing] #386708
07/26/09 11:52 AM
07/26/09 11:52 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Most napas sell pressure switches with different psi ratings , SW has one series that is both open or closed depending on how you wire it , hobbs makes similar senders
Re: Oil Warning light [Re: JandJ_Racing] #386709
07/26/09 11:57 AM
07/26/09 11:57 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
im using a chevy preasure swith for the low oil warning ligth
dont have a part number but there are commen
got it from a napa store ,just ask for a idiot ligth its 1/8 npt
1.39 9.85 - 137 mph
Re: Oil Warning light [Re: Ari440] #386710
07/26/09 12:06 PM
07/26/09 12:06 PM
Way North Illinois
Way North Illinois
every thing they come up with under that is very low psi. I have called three napa stores
Re: Oil Warning light [Re: JandJ_Racing] #386711
07/26/09 12:11 PM
07/26/09 12:11 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
I'm using the stock sending unit hooked up to red trailer type light on my dash.
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Oil Warning light [Re: JandJ_Racing] #386712
07/26/09 12:31 PM
07/26/09 12:31 PM
My 518 stroker idles at or under 20 PSI hot with regular non synthetic 5W20 Valvoline. Same bearings for over three years of street and strip driving, shifting at or above 7000 every shift at the track I do run the bearing clearnances loose, .0035+ on both rods and mains
Re: Oil Warning light [Re: Cab_Burge] #386713
07/26/09 01:43 PM
07/26/09 01:43 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
Moroso used to sell a kit that was set a 15 psi(or so) ...and had a 2" red-lite to go with it.
Re: Oil Warning light [Re: Cab_Burge] #386714
07/26/09 01:56 PM
07/26/09 01:56 PM
Way North Illinois
Way North Illinois
My bearing clearances are the same but I run 20 50 brad penn. I have not seen the gauge drop below 20 but if it did I can look at the gauge. I ordered the 18 psi autometer sender, I all ready have the warning light just never hooked it up
Re: Oil Warning light [Re: JandJ_Racing] #386715
07/26/09 02:07 PM
07/26/09 02:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know why you would hook it up to a light, hook
it to the ignition so if you go below X pressure it
kills the ignition
Re: Oil Warning light [Re: MR_P_BODY] #386716
07/26/09 02:16 PM
07/26/09 02:16 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Thats how I did mine ,hobbs switch thru the msd key feed , if ya dont have 15 psi no spark, I need to turn the engine some on start up so it dosent kick back anyway one switch does both
Re: Oil Warning light [Re: emarine01] #386717
07/26/09 03:36 PM
07/26/09 03:36 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
In my business we use oil pressure switch/gauges on large natural gas engines that are adjustable on the face, the gauges are made by FW Murphy, in a lot of the country you can order these from a NAPA store or if you live in an area where there is oil and natural gas you can buy at a lot of supply stores, I use one of those, mine is hooked to a light, it saved my engine once when I bent a push rod and threw out a lifter about the time I shifted to high gear. You might see if you can find one of those. Here is there homepage, they may have a dealer close to you, they sell a lot of stuff for industrial applications besides oil and gas. http://www.fwmurphy.com/
Re: Oil Warning light [Re: JandJ_Racing] #386718
07/26/09 06:20 PM
07/26/09 06:20 PM
I have a set of cyberdyne digital gauges that are programmable on the high and low temps and pressures, I have the low pressure set at 20 lbs and it starts blinking in gear when the oil temps reach 180F or above at or below 900RPM. If I touch the throttle the oil pressures rises like the tach, it has 30 lbs at 1200 rpm and 63 lbs at 6500 RPM I have thought about using a Hobbs switch to kill the engine but I have never got around to it, probally should now that I mentioned it
Re: Oil Warning light [Re: Cab_Burge] #386719
07/26/09 06:30 PM
07/26/09 06:30 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
The hobbs switch works good, I don't have enough time running in 200 ft to look at the gauges, It has shut down the engine twice on hard breaking on short shut down lanes
Re: Oil Warning light [Re: emarine01] #386720
07/28/09 09:12 AM
07/28/09 09:12 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I used to run a 50psi sender from Moroso. Yes the light was on at idle and in the pits. But you knew if you were having a problem down track.
Doug
Re: Oil Warning light [Re: dvw] #386721
07/28/09 09:54 AM
07/28/09 09:54 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I agree with DVW. If you are using a light preset to 20#, and you have a fast car, when you notice the lite coming on signaling you only have 20# of oil pressure, many times that is going to be too late. You want it to signal you at a higher pressure so that you will notice it, look at the pressure guage BEFORE any damage can occur. The Moroso units come with an adjustable switch that will go up to 50#. I'd suggest a 40-50PSI setting, and yes, the lite will be on at idle. Again, you arent most likely going to blow your engine up at idle. Most racers are concentrating on driving, and by the time they get thru the traps, going thru shutdown is when they start looking at guages etc. This is most likely too late when there is a problem. at least if it comes on at 40 or 50#, you have time to save it and find the problem.
RIP Monte Smith
