Re: Oil Warning light
[Re: JandJ_Racing]
#386709
07/26/09 11:57 AM
07/26/09 11:57 AM
Posts: 5,618 long island NY
Ari440
long island NY
im using a chevy preasure swith for the low oil warning ligth
dont have a part number but there are commen
got it from a napa store ,just ask for a idiot ligth its 1/8 npt
1.39 9.85 - 137 mph
[Re: Cab_Burge]
#386714
07/26/09 01:56 PM
07/26/09 01:56 PM
Posts: 981 Way North Illinois
JandJ_Racing
Way North Illinois
every thing they come up with under that is very low psi. I have called three napa stores
My 518 stroker idles at or under 20 PSI hot with regular non synthetic 5W20 Valvoline. Same bearings for over three years of street and strip driving, shifting at or above 7000 every shift at the track I do run the bearing clearnances loose, .0035+ on both rods and mains
My bearing clearances are the same but I run 20 50 brad penn. I have not seen the gauge drop below 20 but if it did I can look at the gauge. I ordered the 18 psi autometer sender, I all ready have the warning light just never hooked it up
[Re: JandJ_Racing]
#386715
07/26/09 02:07 PM
07/26/09 02:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont know why you would hook it up to a light, hook it to the ignition so if you go below X pressure it kills the ignition
[Re: JandJ_Racing]
#386718
07/26/09 06:20 PM
07/26/09 06:20 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I have a set of cyberdyne digital gauges that are programmable on the high and low temps and pressures, I have the low pressure set at 20 lbs and it starts blinking in gear when the oil temps reach 180F or above at or below 900RPM. If I touch the throttle the oil pressures rises like the tach, it has 30 lbs at 1200 rpm and 63 lbs at 6500 RPM I have thought about using a Hobbs switch to kill the engine but I have never got around to it, probally should now that I mentioned it
[Re: dvw]
#386721
07/28/09 09:54 AM
07/28/09 09:54 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I agree with DVW. If you are using a light preset to 20#, and you have a fast car, when you notice the lite coming on signaling you only have 20# of oil pressure, many times that is going to be too late. You want it to signal you at a higher pressure so that you will notice it, look at the pressure guage BEFORE any damage can occur. The Moroso units come with an adjustable switch that will go up to 50#. I'd suggest a 40-50PSI setting, and yes, the lite will be on at idle. Again, you arent most likely going to blow your engine up at idle. Most racers are concentrating on driving, and by the time they get thru the traps, going thru shutdown is when they start looking at guages etc. This is most likely too late when there is a problem. at least if it comes on at 40 or 50#, you have time to save it and find the problem.
RIP Monte Smith
