Page 2 of 6 1 2 3 4 5 6
Re: Detailed stock 71 340 engine pics needed [Re: ScottSmith_Harms] #385944
07/26/09 08:55 PM
07/26/09 08:55 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Are the white plastic spark plug wire seperators supposed to be engine color or left natural? In the pics posted they all appear natural, that or the paint has flaked off over the years.
My former chall 340 they were missing so I guessed when I did it and painted them. I know big blocks were in fact engine color . and I know later years small blocks are engine color
Re: Detailed stock 71 340 engine pics needed [Re: gtx6970] #385945
07/26/09 09:22 PM
07/26/09 09:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Bill, did the 71 and up with TQ's get a different throttle kickdown assy?
Re: Detailed stock 71 340 engine pics needed [Re: autoxcuda] #385946
07/26/09 09:47 PM
07/26/09 09:47 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
As far as I know the 71 bracket is the same as 1970 ( Same pt # in the parts book ) . I don't have a newer parts book here at the house to say for sure about 72 and newer. But I've seen some newer 360's with what appears to be the exact same bracket on it
Re: Detailed stock 71 340 engine pics needed [Re: gtx6970] #385947
07/26/09 10:09 PM
07/26/09 10:09 PM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
Bill every untouched original wire loom I've seen (the white nylon portion) were bare with no paint, it seems reasonable to assume that they were added just prior to installing the distributor and plug wires. Speaking on painted parts, I have yet to see an original dip stick painted engine color, so far all have been black and the tube engine color. The rubber valve cover grommets, PCV valve, and oil fill cap have all been engine color. I'm speaking on 71 engines painted orange, there may have been variations with different era small blocks.
Re: Detailed stock 71 340 engine pics needed [Re: ScottSmith_Harms] #385948
07/26/09 10:54 PM
07/26/09 10:54 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
I'm guessint the one in my pic is for a 2 bbl manifold, the pic from Bills site looks like the 340 one ( taller and over to the V/C side to line up better with the T-quad linkage), and a 72 one that i have is set up for what i think was a different kickdown setup without the threaded end. i'll post a pic of the 72 in a bit. One thing is for sure, no one is 100% on 340's Maybe i can get a hold of Rhinodart to see if Bill's car is in chicagoland area, and spend an hour taking pic's and verifying bolt , kickdown, brackets, ect...
Re: Detailed stock 71 340 engine pics needed [Re: ademon] #385949
07/26/09 10:58 PM
07/26/09 10:58 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
A truer statement would be that no one is 100% sure on any Mopar engine detail, some better than others but there are debatable items on almost all of them. 340 details are known quite well by a few, but it's a small number at this time. There are still some minor details that get debated, just as on other Mopar engines.
*Bills Demon (and Jim Rhineheart) are in Scotsdale AZ right now, just spoke with him today
Re: Detailed stock 71 340 engine pics needed [Re: ScottSmith_Harms] #385950
07/26/09 11:57 PM
07/26/09 11:57 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
And every year 340 is a little different too. And you have the 340 six packs that are an animal in thier own. Because of TA/AAR values those engines are more researched out.
And didn't the the 340 TQ's in 71 have a recall or some issue? And most were swapped to a 72 TQ. Making a survivor with the OE carb even harder to find. When someone back in the day does a carb swap stuff gets disturbed at the same time. That's got to make it tough to find 71 info.
Is they why the orange Demon has it's carb switched?
Re: Detailed stock 71 340 engine pics needed [Re: autoxcuda] #385951
07/27/09 12:01 AM
07/27/09 12:01 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Not a recall, but if serviced for carb issues there was some service bullitin that reccomend a 72 TQ as a replacment.
The Demon had some kind of problem back in the day, small carb fire or something, as a result it is also wearing some touch up engine paint on the intake and drivers VC
Re: Detailed stock 71 340 engine pics needed [Re: ScottSmith_Harms] #385952
07/27/09 12:51 AM
07/27/09 12:51 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
my demon still retains its original 71 carb but its far from a reference example. i have the majority of the correct ($$$) parts now just a few more peices and i will be ready to start the resto.
Re: Detailed stock 71 340 engine pics needed [Re: chrisf] #385953
07/27/09 01:31 AM
07/27/09 01:31 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Looks nice to me Just having the original carb and what looks to be the original master cyl puts you way ahead of the game !!
Re: Detailed stock 71 340 engine pics needed [Re: ScottSmith_Harms] #385954
07/27/09 07:27 AM
07/27/09 07:27 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Scott,
the 340 I'm building now for a customer came out of a 1970 duster 340 back in the early to mid-eighties. and the tube and dipstick are both engine color.(orange) I have no reason to think either have ever been touched
Re: Detailed stock 71 340 engine pics needed [Re: gtx6970] #385955
07/27/09 09:35 AM
07/27/09 09:35 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I wouldn't doubt it Bill, just haven't seen it myself, have any pics?
Re: Detailed stock 71 340 engine pics needed [Re: ScottSmith_Harms] #385956
07/27/09 10:24 AM
07/27/09 10:24 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
heres what a think is a 72 and later 340/360 4 bbl throttle bracket, with the pic of a 71 style above.
Re: Detailed stock 71 340 engine pics needed [Re: ademon] #385957
07/27/09 10:47 AM
07/27/09 10:47 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here are the two different 71 340 intake castings shown side by side to show the differences.
Re: Detailed stock 71 340 engine pics needed [Re: ScottSmith_Harms] #385958
07/27/09 10:50 AM
07/27/09 10:50 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Same casting number and physically the same at a glance but look further and......
Re: Detailed stock 71 340 engine pics needed [Re: ScottSmith_Harms] #385959
07/27/09 11:14 AM
07/27/09 11:14 AM
NY
F1Scamp Offline
F1Scamp  Offline
NY
I wonder which one flows better
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Detailed stock 71 340 engine pics needed [Re: ademon] #385960
07/27/09 12:50 PM
07/27/09 12:50 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
this is great reading. unfortunately i don't have too much to add. i can't seem to locate my original throttle bracket. i have an idea to what it is so this has been a help. wish i had more pics of when i got my challenger in 1990. here is one of the few. enjoy, Greg
Re: Detailed stock 71 340 engine pics needed [Re: ademon] #385961
07/27/09 01:25 PM
07/27/09 01:25 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Would dmoore's survivor 72 340 4speed Duster have the correct bracket? This one looks like the same one for 68-70? 340's that you can buy new....
https://board.moparts.org/ubbthreads/show...e=0#Post5023423
Re: Detailed stock 71 340 engine pics needed [Re: autoxcuda] #385962
07/27/09 02:01 PM
07/27/09 02:01 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Ya, that looks like the 68-71 style, the pic of the 72 that i listed is going by an old Year One cataloge that they say is 72 and later 340/360 4bbl, Maybe that style showed up later in the 72 year? the pic of that 72 does look to have the original PCV Valve,
Re: Detailed stock 71 340 engine pics needed [Re: ademon] #385963
07/27/09 02:18 PM
07/27/09 02:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Also notice that the 72 has had some new engine paint added, be careful what paint details you copy from it
