Wiring for a RR 'meep meep' horn #382319
07/21/09 06:05 PM
07/21/09 06:05 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I have a RR horn, it only has one prong on the back to hook a wire to. I have a button on the dash that used to be for purging nitrous, I'm gonna use that for the horn button. I figured I'd just run a power wire to the horn from the dash button but a buddy of mine thinks the RR horns had to have some special relay to work properly.
How do you wire these?
Re: Wiring for a RR 'meep meep' horn [Re: ProSport] #382320
07/21/09 06:25 PM
07/21/09 06:25 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Very cool idea! I've been thinking of making the horn buttons(not centered type) either a line lock hold or nos hold.
Didn't mean to hijack your thread. Good luck.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Wiring for a RR 'meep meep' horn [Re: ProSport] #382321
07/21/09 06:30 PM
07/21/09 06:30 PM
okla.
O
okie Offline
okie  Offline
O
okla.
I know it has a relay but I think they all do so all you have to do is hook up 1 of your horn wires to it. That is the way I've all ways done it. Good Luck! Ronnie in Okla.
Re: Wiring for a RR 'meep meep' horn [Re: okie] #382322
07/21/09 07:15 PM
07/21/09 07:15 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
This is a street strip race car so there's no relay or horn wire, just starting from scratch.
I'm basically just asking if I can run a power wire straight to the horn, maybe with an in-line fuse for safety. And does it ground just by bolting the horn to the car?
Re: Wiring for a RR 'meep meep' horn [Re: Hoof Hearted] #382323
07/21/09 07:15 PM
07/21/09 07:15 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Horns need a lot more current than your stock steering wheel horn button will flow, which is why they used the relay. Plus the way they did it simplified the wiring. You push the horn button and it ground the switch feed to the relay, which then in turn sends a 12v + feed to the horn.
Re: Wiring for a RR 'meep meep' horn [Re: ProSport] #382324
07/21/09 07:21 PM
07/21/09 07:21 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
You do not have to have a relay but it is recommended. If you used the standard bosch style relays they sell over the counter, you could do this.
  • 85 will go to the switch
  • the other end of the switch will go a good ground
  • 87 will go to the horn
  • Put a wire on 30 that will jump to 86 as well, then thru a 5-7.5 amp fuse and finally to the big post on the starter relay or other battery voltage source.
  • make sure the horn is grounded well.
Re: Wiring for a RR 'meep meep' horn [Re: ProSport] #382325
07/21/09 07:47 PM
07/21/09 07:47 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
The horn for the Road Runner was actuated through a relay. The relay was "closed" by completing the ground at the horn switch. That way, a higher current load could be passed through the relay instead of through the horn button, whcih would probably cause it to wear out faster.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Wiring for a RR 'meep meep' horn [Re: RoadRunner] #382326
07/21/09 07:49 PM
07/21/09 07:49 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
For what its worth, Testors(model car paint) sells a lilac paint that is a spot on match for the purple color of these horns. The decal is available at places like year one.
Re: Wiring for a RR 'meep meep' horn [Re: ProSport] #382327
07/21/09 07:51 PM
07/21/09 07:51 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I took the OEM horn out of my Dad's Road Runner and put it in my Duster when I was 16.It worked fine.No special relay was made or needed for the RR horn to work.
Nautilus Racing-
Re: Wiring for a RR 'meep meep' horn [Re: HealthServices] #382328
07/21/09 07:52 PM
07/21/09 07:52 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Thanks! That's exactly what I was looking for.
Re: Wiring for a RR 'meep meep' horn [Re: Chris2581] #382329
07/21/09 08:17 PM
07/21/09 08:17 PM
The reason it worked in your duster is if you hooked it to the factory wiring, there ALREADY WAS a horn relay in the car.
Re: Wiring for a RR 'meep meep' horn #382330
07/21/09 08:21 PM
07/21/09 08:21 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Ya think?? I posted because of the other posts saying a "special relay" was needed.
Nautilus Racing-
Re: Wiring for a RR 'meep meep' horn [Re: Chris2581] #382331
07/21/09 08:30 PM
07/21/09 08:30 PM
The way I read his post, he's saying he doesn't HAVE the factory horn wiring. Ya think?
Re: Wiring for a RR 'meep meep' horn [Re: ProSport] #382332
07/21/09 10:53 PM
07/21/09 10:53 PM
NJ
440challenger Offline
NJ
Anyone know where the horn relay mounts and what wires go to it on a 68 runner? Is it under the dash or in the engine compartment?
Re: Wiring for a RR 'meep meep' horn [Re: 440challenger] #382333
07/21/09 11:11 PM
07/21/09 11:11 PM
So Cal
So Cal
In the engine compartment near the horn I think. Don't know if this is a 68,69, or 70
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Wiring for a RR 'meep meep' horn [Re: HealthServices] #382334
07/22/09 05:33 PM
07/22/09 05:33 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
my 70 runner,relay is under the dash,mounted 6" to the left of the ashtray
