Wiring for a RR 'meep meep' horn
#382319
07/21/09 06:05 PM
07/21/09 06:05 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I have a RR horn, it only has one prong on the back to hook a wire to. I have a button on the dash that used to be for purging nitrous, I'm gonna use that for the horn button. I figured I'd just run a power wire to the horn from the dash button but a buddy of mine thinks the RR horns had to have some special relay to work properly.
How do you wire these?
Re: Wiring for a RR 'meep meep' horn
[Re: ProSport]
#382320
07/21/09 06:25 PM
07/21/09 06:25 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Very cool idea! I've been thinking of making the horn buttons(not centered type) either a line lock hold or nos hold.
Didn't mean to hijack your thread. Good luck.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
[Re: ProSport]
#382325
07/21/09 07:47 PM
07/21/09 07:47 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
The horn for the Road Runner was actuated through a relay. The relay was "closed" by completing the ground at the horn switch. That way, a higher current load could be passed through the relay instead of through the horn button, whcih would probably cause it to wear out faster.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: ProSport]
#382327
07/21/09 07:51 PM
07/21/09 07:51 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I took the OEM horn out of my Dad's Road Runner and put it in my Duster when I was 16.It worked fine.No special relay was made or needed for the RR horn to work.
[Re: Chris2581]
#382329
07/21/09 08:17 PM
07/21/09 08:17 PM
The reason it worked in your duster is if you hooked it to the factory wiring, there ALREADY WAS a horn relay in the car.
[Re: Chris2581]
#382331
07/21/09 08:30 PM
07/21/09 08:30 PM
Ya think?? I posted because of the other posts saying a "special relay" was needed.
The way I read his post, he's saying he doesn't HAVE the factory horn wiring. Ya think?
