Mechanical six pack carbs??
#378875
07/18/09 02:59 PM
07/18/09 02:59 PM
Posts: 1,946 Connecticut
5126brl No more
Connecticut
Are the old Mechanical carbs still around? I know they had acc. pumps on each carb. Thinking of making a change after this last track day! ![](/ubbthreads/images/graemlins/frown.gif) Stick and vacumm outboards was no fun!
Re: Mechanical six pack carbs??
[Re: 5126brl No more]
#378876
07/18/09 03:08 PM
07/18/09 03:08 PM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
Thats what I have always used,e-bay/swapmeets etc............
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
#378877
07/18/09 03:12 PM
07/18/09 03:12 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I love 'em! Found this last set on ebay several years ago.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
#378879
07/18/09 03:19 PM
07/18/09 03:19 PM
jbc426
West Coast, USA
They are the old Direct Connection/Mopar Performance Racing carbs that they used to sell years ago. This last set I got was brand new, never used. Unbelievable! It will be a while until I can get the list numbers for you as the car is masked off for some finish bodywork and paint. I'll see if I can cut a little hole in the plastic and peak at the numbers for you.
I had Ben over at Promax mill off the choke horn and do a few other of his little tricks to them. They still have the linkage and such available over there.
#378881
07/18/09 03:50 PM
07/18/09 03:50 PM
You're not supposed to let up on the gas pedal when shifting............. ![](/ubbthreads/images/graemlins/biggrin.gif)
#378882
07/18/09 03:55 PM
07/18/09 03:55 PM
5126brl No more
Connecticut
OH I never lifted, I just could not get it to leave worth a dam . best 60 ft was a 1.93 while leaving at 3000 rpm. Any higher and it would launch die then spin.Could not get into second till past the 60ft mark.After that it was great right to 6000 every shift!
#378883
07/18/09 03:59 PM
07/18/09 03:59 PM
i used the mechanical 6 pack carbs by direct connection also back in the mid 70's, they worked great, yes the pedal was tougher to depress but well worth it. i went from 12.teens to 11.97 with the carb swap. iremember going into East Coast Speed shop in Yonkers NY with a shopping cart and buying those direct connection carbs as well as a Accel electronic distributor, electric fuel pump ,sun gauge, my engine breaking up problem was solved and my plugs lasted alot longer. i think i spent around $550.00 that day, which was huge money then.
[Re: RUNCHARGER]
#378887
07/18/09 06:10 PM
07/18/09 06:10 PM
quick77rt
Parts Problem
Parts Problem
4782 and 4783 are the #'s. I also feel they are superior to the vacuum carbs.
Stock for stock or overall???
My quickfeul/promax carbs do very well, I wonder how these (mech) would do modified????...Hmmmmm
Sheldon
[Re: quick77rt ]
#378888
07/19/09 09:42 AM
07/19/09 09:42 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Could anyone give me the phone # or web site for Promax? Thanks
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
