Mechanical six pack carbs?? #378875
07/18/09 02:59 PM
07/18/09 02:59 PM
Connecticut
5126brl No more Offline OP
Connecticut
Are the old Mechanical carbs still around?
I know they had acc. pumps on each carb.
Thinking of making a change after this last track day!
Stick and vacumm outboards was no fun!
Re: Mechanical six pack carbs?? [Re: 5126brl No more] #378876
07/18/09 03:08 PM
07/18/09 03:08 PM
N.E. Ohio
6bblFLASH Online content
6bblFLASH  Online Content
N.E. Ohio
Thats what I have always used,e-bay/swapmeets etc............
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Mechanical six pack carbs?? [Re: 5126brl No more] #378877
07/18/09 03:12 PM
07/18/09 03:12 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I love 'em! Found this last set on ebay several years ago.
Re: Mechanical six pack carbs?? [Re: 6bblFLASH] #378878
07/18/09 03:13 PM
07/18/09 03:13 PM
Connecticut
Connecticut
Thanks, what is the part number on those?
Re: Mechanical six pack carbs?? [Re: 5126brl No more] #378879
07/18/09 03:19 PM
07/18/09 03:19 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
They are the old Direct Connection/Mopar Performance Racing carbs that they used to sell years ago. This last set I got was brand new, never used. Unbelievable! It will be a while until I can get the list numbers for you as the car is masked off for some finish bodywork and paint. I'll see if I can cut a little hole in the plastic and peak at the numbers for you.
I had Ben over at Promax mill off the choke horn and do a few other of his little tricks to them. They still have the linkage and such available over there.
Re: Mechanical six pack carbs?? [Re: jbc426] #378880
07/18/09 03:26 PM
07/18/09 03:26 PM
Connecticut
Connecticut
When I was 15 I had a set on a 383 runner I bought.
I remember that the pedal was hard to push with three acc. pumps.
I sold them back then with the intake for $300.
Re: Mechanical six pack carbs?? [Re: 5126brl No more] #378881
07/18/09 03:50 PM
07/18/09 03:50 PM
You're not supposed to let up on the gas pedal when shifting.............
Re: Mechanical six pack carbs?? #378882
07/18/09 03:55 PM
07/18/09 03:55 PM
Connecticut
Connecticut
OH I never lifted, I just could not get it to leave worth a dam . best 60 ft was a 1.93 while leaving at 3000 rpm. Any higher and it would launch die then spin.Could not get into second till past the 60ft mark.After that it was great right to 6000 every shift!
Re: Mechanical six pack carbs?? [Re: 5126brl No more] #378883
07/18/09 03:59 PM
07/18/09 03:59 PM
i used the mechanical 6 pack carbs by direct connection also back in the mid 70's, they worked great, yes the pedal was tougher to depress but well worth it. i went from 12.teens to 11.97 with the carb swap.
iremember going into East Coast Speed shop in Yonkers NY with a shopping cart and buying those direct connection carbs as well as a Accel electronic distributor, electric fuel pump ,sun gauge,
my engine breaking up problem was solved and my plugs lasted alot longer.
i think i spent around $550.00 that day, which was huge money then.
Re: Mechanical six pack carbs?? #378884
07/18/09 05:01 PM
07/18/09 05:01 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I just got a decent nos set of them not long ago, just to try for kicks. Ive had no issues with the vac carbs yet though..
Re: Mechanical six pack carbs?? [Re: quick77rt ] #378885
07/18/09 05:10 PM
07/18/09 05:10 PM
Connecticut
Connecticut
I think you won't not like them! So I will take them
Re: Mechanical six pack carbs?? [Re: 5126brl No more] #378886
07/18/09 06:06 PM
07/18/09 06:06 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
4782 and 4783 are the #'s. I also feel they are superior to the vacuum carbs.
Sheldon
Re: Mechanical six pack carbs?? [Re: RUNCHARGER] #378887
07/18/09 06:10 PM
07/18/09 06:10 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Stock for stock or overall???
My quickfeul/promax carbs do very well, I wonder how these (mech) would do modified????...Hmmmmm
Sheldon
Re: Mechanical six pack carbs?? [Re: quick77rt ] #378888
07/19/09 09:42 AM
07/19/09 09:42 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Could anyone give me the phone # or web site for Promax? Thanks
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
