Hologen headlamp conversion #377405
07/16/09 04:46 PM
07/16/09 04:46 PM
dark side of the moon
Dougsmopars Offline OP
Does anyone make a good conversion buld set up? Most of the ones i've seen all look like motorcycle headlamps. I'd like to try and stay stock looking. Any compianes make the lens houseings that look like stock sealed beams?
Re: Hologen headlamp conversion [Re: Dougsmopars] #377406
07/16/09 04:52 PM
07/16/09 04:52 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Best thing to do to start is go with a relay set up so you will at least get battery voltage at the headlight.
80% of the headlights sold now are at least halogen over the counter. If you want to step up from that you can go to a Hella headlamp setup.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Hologen headlamp conversion [Re: HealthServices] #377407
07/16/09 04:58 PM
07/16/09 04:58 PM
I have the relay kit. I'm looking for something like Hella. But i want to keep them looking stock. All the ones i've seen so far are clear flat glass like a motorcycle. I'd like to find some that look like stock sealed beams
Re: Hologen headlamp conversion [Re: Dougsmopars] #377408
07/16/09 05:11 PM
07/16/09 05:11 PM
So Cal
So Cal
Re: Hologen headlamp conversion [Re: HealthServices] #377409
07/16/09 05:13 PM
07/16/09 05:13 PM
So Cal
So Cal
Re: Hologen headlamp conversion [Re: HealthServices] #377410
07/16/09 05:17 PM
07/16/09 05:17 PM
If you want "stock looking" what's wrong with halogen sealed beams?
Re: Hologen headlamp conversion #377411
07/16/09 05:19 PM
07/16/09 05:19 PM
So Cal
So Cal
Basically you are looking for a h5006 bulb (low beam) but in a seal beam though right?
Re: Hologen headlamp conversion [Re: HealthServices] #377412
07/16/09 07:07 PM
07/16/09 07:07 PM
Those would work. Do they take the H4 bulbs?
Re: Hologen headlamp conversion #377413
07/16/09 07:09 PM
07/16/09 07:09 PM
Hologen sealed beams are not as bright as the newer hologen lights.
Re: Hologen headlamp conversion [Re: Dougsmopars] #377414
07/16/09 07:11 PM
07/16/09 07:11 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
But are they very much brighter than standard bulbs?
Re: Hologen headlamp conversion [Re: Dougsmopars] #377415
07/16/09 09:04 PM
07/16/09 09:04 PM
I think a lot of the difference is in your minds
It depends on the wattage of whatever "hologen lights" you are talking about, but the REALLY big thing is that these old girls never had decent SIZED wiring to begin with. Putting lamp relays out under the hood with larger wire feeds helps immensely
Re: Hologen headlamp conversion [Re: Dougsmopars] #377416
07/16/09 09:21 PM
07/16/09 09:21 PM
So Cal
So Cal
When you click the link for the picture it says H4 in the center of the bulb. So I would say yes.
http://www.myhellalights.com/halogen_lamps/5.75_inch_Round_Conversion_Headlamp.html#
Re: Hologen headlamp conversion [Re: HealthServices] #377417
07/16/09 09:34 PM
07/16/09 09:34 PM
Just ordered a set from summit
Re: Hologen headlamp conversion [Re: Dougsmopars] #377418
07/16/09 09:42 PM
07/16/09 09:42 PM
Toronto, Ontario, Canada
plazomat Offline
plazomat  Offline
Keep us in the loop, I am looking into this for next year after the 120A alternator upgrade...
Plaz
Re: Hologen headlamp conversion [Re: plazomat] #377419
07/17/09 12:16 AM
07/17/09 12:16 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Sealed beam headlamps and headlamp housings which take a replaceable bulb (such as an H4) are totally different.
Do you want more light, more brightness, or a better light pattern?
I suggest you check out the info at www.rallylights.com regarding light patterns and the differences in U.S. and European code conversion headlamps.
Re: Hologen headlamp conversion [Re: In_The_Pink] #377420
07/17/09 08:04 PM
07/17/09 08:04 PM
I checked out that link. Didn't find any info on light patterns. I'm looking for a brighter , whiter light. And yes i know there different. Orignal question was who makes a good conversion headlamp.
Re: Hologen headlamp conversion [Re: Dougsmopars] #377421
07/17/09 10:35 PM
07/17/09 10:35 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I checked out that link. Didn't find any info on light patterns. I'm looking for a brighter, whiter light. And yes i know there different.
Look here: http://www.rallylights.com/hella/Beams.aspx
Hella makes an excellent conversion headlamp. I've used Hella E-code conversion lamps on three of my vehicles which previously used sealed beam halogen bulbs and highly recommend them to everyone.
Re: Hologen headlamp conversion [Re: Dougsmopars] #377422
07/17/09 11:22 PM
07/17/09 11:22 PM
Shoreline, Washington
72roadrunnergtx Offline
I will second that.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Hologen headlamp conversion [Re: 72roadrunnergtx] #377423
07/17/09 11:31 PM
07/17/09 11:31 PM
plazomat Offline
plazomat  Offline
Anyone ever use these Autopal from Ebay...
http://cgi.ebay.com/ebaymotors/5-3%2F4"-...261810004r35980
How do they work?
Plaz
Re: Hologen headlamp conversion [Re: plazomat] #377424
07/18/09 04:44 PM
07/18/09 04:44 PM
If those are the ones from Pro Street Lighting stay very far away. There junk. I bought a set. The reflectors were falling off the bulbs didn't even fit the housings. Cheap China made crap. Sent them back for a refund but still lost 30 bucks on shipping. I just got my Hella's from Summit. They look great. H4 and H1 high beam set. Going to install maybe tomorrow with my relay kit.
