Re: Fresh rebuild on 360 "ticking" at all RPMs
[Re: 69 Road Chicken]
#372871
07/12/09 12:02 AM
07/12/09 12:02 AM
Just for grins pull the distributor and see if the galley plug --the one on the inside there at the oil pump drive gear is in ( Drivers side oil galley rear plug )--if it is out engine will run fine with OK pressure until you drop RPM and it gets warm--will tick like crazy--pressure will drop like a rock when RPM goes down--who knows until you look--easy fix if it is missing--just takes some finger gymnastics--all or most small block guys get to see this on the FIRST build they do. Never again though--Good Luck
[Re: ]
#372872
07/12/09 12:09 AM
07/12/09 12:09 AM
Posts: 1,039 Redwood City Ca.
B1arno
Redwood City Ca.
Just went thru this exact same thing with a fresh 340. The gallery plug was not installed. Pull the distibutor and use a mirror and a flashlight. I pulled the intake and with a little creativity you can install the plug. Arno
#372874
07/12/09 08:41 AM
07/12/09 08:41 AM
RapidRobert
See what you have for lifter preload
[Re: RapidRobert]
#372876
07/12/09 10:27 AM
07/12/09 10:27 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Not an exhaust leak is it?
Or a Fram filter?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: RapidRobert]
#372881
07/14/09 02:34 AM
07/14/09 02:34 AM
Posts: 4,803 Castlegar, BC, Canada
That AMC Guy
Been through this with an old 318 and just recently, the 304 in my yellow Hornet. After a cam & lifter swap, had some valve tick. In my case, my pushrods and rocker bridges had some pretty significant wear. Installing new rocker bridges and slightly longer pushrods quieted everything up.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
