V6/V8 Neutral Balance Flywheel interchange..... #372113
07/10/09 11:54 PM
07/10/09 11:54 PM
IMGTX Offline OP
IMGTX  Offline OP
Is a manual transmission flywheel from an 88 dodge 1/2ton truck with a v-6 neutral balanced and is it the same as the old 130 tooth small block flywheels?
If not what are the late model v-6's that I should look for?
Re: V6/V8 Neutral Balance Flywheel interchange..... [Re: IMGTX] #372114
07/11/09 12:51 PM
07/11/09 12:51 PM
IMGTX Offline OP
IMGTX  Offline OP
Bump for the morning crowd.
Re: V6/V8 Neutral Balance Flywheel interchange..... [Re: IMGTX] #372115
07/11/09 05:57 PM
07/11/09 05:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Probably, but I'd check to see if it had an A833OD in then, yes. If it had an NP435 (could it get one?) then no.
As for the V6 Dakota wheel, I believe I used a pre Magnum Dakota as my source, been a while.
Don't be the exception.
Re: V6/V8 Neutral Balance Flywheel interchange..... [Re: Supercuda] #372116
07/11/09 08:45 PM
07/11/09 08:45 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
It was a 5 speed.
Is that the same 5 speed as goes in the Dakota? Love to have a 5 speed slant in a Duster! Pattern on the bell look like it might swap.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: V6/V8 Neutral Balance Flywheel interchange..... [Re: Rug_Trucker] #372117
07/12/09 12:13 PM
07/12/09 12:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A slant? Not in front of a five speed, stock.
the V6 is the same pattern as the LA, not the slant.
Back in the 60's Dodge trucks had a dual pattern bellhousing that was cast iron, large and heavy, but it had the slant anf the LA pattern on it, but the NP435 was bolted to it.
I know guys have put T5's behind slants, check out slansix.org, I believe, for details.
Re: V6/V8 Neutral Balance Flywheel interchange..... [Re: IMGTX] #372118
07/12/09 12:20 PM
07/12/09 12:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
To answer the question , neutral balance is neutral balance , if it will bolt on it will work .
Re: V6/V8 Neutral Balance Flywheel interchange..... [Re: Supercuda] #372119
07/12/09 12:43 PM
07/12/09 12:43 PM
Rug_Trucker Offline
Rug_Trucker  Offline
I know the bell won't fit. The tranny is what I am wondering about. I know I looked at a Dakota tranny and it looked like it was tall enough to have to cut into the dash on an A body.
Just didn't know if that is the same as in the full size '88 truck. I do have several 3/4 speed bells for the slant.
Re: V6/V8 Neutral Balance Flywheel interchange..... [Re: JohnRR] #372120
07/14/09 01:00 PM
07/14/09 01:00 PM
IMGTX Offline OP
IMGTX  Offline OP
I was hoping somebody would know if that flywheel was neutral balance and if it was a 130 tooth without me having to pull it.
I get paid Tomorrow so if it is a good prospect I may hit the Junkyard Thursday. I just hate to pull it for no reason.
Re: V6/V8 Neutral Balance Flywheel interchange..... [Re: IMGTX] #372121
07/14/09 02:33 PM
07/14/09 02:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you didn't ask that question ..
ask in the truck forum ???
