Re: V6/V8 Neutral Balance Flywheel interchange.....
[Re: Rug_Trucker]
#372117
07/12/09 12:13 PM
07/12/09 12:13 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A slant? Not in front of a five speed, stock.
the V6 is the same pattern as the LA, not the slant.
Back in the 60's Dodge trucks had a dual pattern bellhousing that was cast iron, large and heavy, but it had the slant anf the LA pattern on it, but the NP435 was bolted to it.
I know guys have put T5's behind slants, check out slansix.org, I believe, for details.
[Re: IMGTX]
#372118
07/12/09 12:20 PM
07/12/09 12:20 PM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
Is a manual transmission flywheel from an 88 dodge 1/2ton truck with a v-6 neutral balanced and is it the same as the old 130 tooth small block flywheels?
If not what are the late model v-6's that I should look for?
To answer the question , neutral balance is neutral balance , if it will bolt on it will work .
[Re: Supercuda]
#372119
07/12/09 12:43 PM
07/12/09 12:43 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I know the bell won't fit. The tranny is what I am wondering about. I know I looked at a Dakota tranny and it looked like it was tall enough to have to cut into the dash on an A body.
Just didn't know if that is the same as in the full size '88 truck. I do have several 3/4 speed bells for the slant.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: JohnRR]
#372120
07/14/09 01:00 PM
07/14/09 01:00 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
I was hoping somebody would know if that flywheel was neutral balance and if it was a 130 tooth without me having to pull it.
I get paid Tomorrow so if it is a good prospect I may hit the Junkyard Thursday. I just hate to pull it for no reason.
[Re: IMGTX]
#372121
07/14/09 02:33 PM
07/14/09 02:33 PM
JohnRR
U.S.S.A.
you didn't ask that question ..
ask in the truck forum ???
