Dwell Settings #370068
07/08/09 04:37 PM
07/08/09 04:37 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
What should the point gap be on a single point distributor on a stock internal 383 with an Edelbrock performer intake and 650 double pumper carb and headers?
What about the dwell?
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Dwell Settings [Re: MoparJ] #370069
07/08/09 04:39 PM
07/08/09 04:39 PM
scratchnfotraction Offline
points gap about .017 and about 30* dwell IIRC
Re: Dwell Settings [Re: MoparJ] #370070
07/08/09 04:46 PM
07/08/09 04:46 PM
.016" & 30. You can lower the point gap a few thou which wii increase (lengthen)the dwell(the # of degrees(time) the points are closed which will give more coil saturation(a hotter spark) but slightly shorten the points service life.
Re: Dwell Settings [Re: RapidRobert] #370071
07/08/09 06:14 PM
07/08/09 06:14 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Most of the singles that I had seemed to be 30-31 at .014"
Re: Dwell Settings [Re: 500ciDuster] #370072
07/08/09 08:47 PM
07/08/09 08:47 PM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
thinking way back, I recall 28-32 being exceptable...I would shoot for the high side, that way, when the rubbing block wears, the dwell will still be in range...
Re: Dwell Settings [Re: cornucopia] #370073
07/08/09 09:49 PM
07/08/09 09:49 PM
The problem with factory aluminum Mopar single point units is that "they are so bad", even the "tighter ones" that often, you had to "fudge" the dwell/ gap to come to a "happy medium" EVERYTHING in those units changes with rpm, vacuum, etc. You can only see this clearly on a 'scope.
My recollection--and I haven't worked with any of these for years--is that they tend to go towards "open" (points gap) as rpm/ vacuum goes up
