Dwell Settings
#370068
07/08/09 04:37 PM
07/08/09 04:37 PM
Posts: 992 Simi Valley, CA
MoparJ
Simi Valley, CA
What should the point gap be on a single point distributor on a stock internal 383 with an Edelbrock performer intake and 650 double pumper carb and headers?
What about the dwell?
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Dwell Settings
[Re: MoparJ]
#370070
07/08/09 04:46 PM
07/08/09 04:46 PM
RapidRobert
.016" & 30. You can lower the point gap a few thou which wii increase (lengthen)the dwell(the # of degrees(time) the points are closed which will give more coil saturation(a hotter spark) but slightly shorten the points service life.
Re: Dwell Settings
[Re: cornucopia]
#370073
07/08/09 09:49 PM
07/08/09 09:49 PM
The problem with factory aluminum Mopar single point units is that "they are so bad", even the "tighter ones" that often, you had to "fudge" the dwell/ gap to come to a "happy medium" EVERYTHING in those units changes with rpm, vacuum, etc. You can only see this clearly on a 'scope.
My recollection--and I haven't worked with any of these for years--is that they tend to go towards "open" (points gap) as rpm/ vacuum goes up
