Page 2 of 4 1 2 3 4
Re: R5P7 DART TO TEST FRIDAY [Re: B3422W5] #364230
07/02/09 06:09 PM
07/02/09 06:09 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
Dang, has anyone else run a P7 headed combo? Please take some video of both the launch and top end!!
diego
Re: R5P7 DART TO TEST FRIDAY [Re: Diego_Ted] #364231
07/02/09 11:24 PM
07/02/09 11:24 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Good luck Boyz
Re: R5P7 DART TO TEST FRIDAY [Re: 340RICK] #364232
07/03/09 11:11 AM
07/03/09 11:11 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
Good luck! I REALLY hope to see some video clip of your run if possible. Hopefully you hit some mid 9 seconds at least for beginning
What gear you run and what stall converter you have?
My car combo is similar of yours...
One more time - good luck!
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: R5P7 DART TO TEST FRIDAY [Re: Georg] #364233
07/03/09 11:13 AM
07/03/09 11:13 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
5.13 gear with 28 by 10.5 tire
Convertor is likely going to flash 56-5800
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: R5P7 DART TO TEST FRIDAY [Re: Diego_Ted] #364234
07/03/09 11:14 AM
07/03/09 11:14 AM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
diego
Big X2 on that !
Re: R5P7 DART TO TEST FRIDAY [Re: B3422W5] #364235
07/03/09 11:26 AM
07/03/09 11:26 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
He is figuring to zing it 8500-8800 or so, he is hoping it has ENOUGH gear
BTW that 735 ponies was with a 390 carb on it ..it has a carb shop 950 on it now
that dyno was done at Arringtons shop....
Scott took one of the heads off and had a guy pretty famous around these parts(Jerry Arnold)flow it, and it stopped just a smidgen short of 400cfm
Sounds like you have an old Busch/Truck motor (those 390's really flow over 600), with a restrictor plate cam, did you already dyno to 8800 rpm with that 248/258 cam?
Re: R5P7 DART TO TEST FRIDAY [Re: LSP] #364236
07/03/09 11:31 AM
07/03/09 11:31 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
That is what he has
Not sure on the dyno info i know that is what Arrington told him, but not sure about where it made what power at.
Will be interesting to see how it runs and how the convertor he has will work.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: R5P7 DART TO TEST FRIDAY [Re: B3422W5] #364237
07/03/09 11:40 AM
07/03/09 11:40 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
That is what he has
Hope the valvetrain's safe at the rpm you want to turn, take er easy at first, have fun, and good luck!
Re: R5P7 DART TO TEST FRIDAY [Re: LSP] #364238
07/03/09 11:42 AM
07/03/09 11:42 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
That is what he has
should be, its all Ti stuff with Jesel keyway lifters
1.41 best 60 foot
6.60 at 103.90 1/8
Re: R5P7 DART TO TEST FRIDAY [Re: B3422W5] #364239
07/03/09 11:49 AM
07/03/09 11:49 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
That is what he has
It's the other side (springs) I'd be concerned with, those old plate motors didn't turn that kind of rpm.
Re: R5P7 DART TO TEST FRIDAY [Re: LSP] #364240
07/03/09 10:12 PM
07/03/09 10:12 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
got the call from scott
congrats on the first outting in the car
i will let him fill you guys in
Re: R5P7 DART TO TEST FRIDAY [Re: BobsProFab] #364241
07/03/09 11:28 PM
07/03/09 11:28 PM
Renton Washington
Triple Threat Offline
Renton Washington
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: R5P7 DART TO TEST FRIDAY [Re: Triple Threat] #364242
07/04/09 02:12 AM
07/04/09 02:12 AM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Re: R5P7 DART TO TEST FRIDAY [Re: abodiesonly1] #364243
07/04/09 03:15 AM
07/04/09 03:15 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
Re: R5P7 DART TO TEST FRIDAY [Re: Georg] #364244
07/04/09 09:47 AM
07/04/09 09:47 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: R5P7 DART TO TEST FRIDAY [Re: Triple Threat] #364245
07/04/09 09:53 AM
07/04/09 09:53 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
x2
Re: R5P7 DART TO TEST FRIDAY [Re: Dunnuck Racing] #364246
07/04/09 11:01 AM
07/04/09 11:01 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
Re: R5P7 DART TO TEST FRIDAY [Re: SB449VALIANT] #364247
07/04/09 11:37 AM
07/04/09 11:37 AM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
I only got 1 pass had some header troubles the car did go 1.34 60 ft it was over geared will pull some gear out this wk .So here is the brake down 1.34 60ft 111mhp at the 1/8 mile and 9.71 @134.96 so not so bad for the only pass the car has made Im still running the mech water pump have not a clue on the jetting or timing yet the motor is just the way it was when I got
Re: R5P7 DART TO TEST FRIDAY [Re: scottb] #364248
07/04/09 11:49 AM
07/04/09 11:49 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
he actually went 135.60 mph
the car laid down the last couple of hundred feet and trapped at 8700
from the look of things, it appears that a trap of 8000 will be in the cars wheelhouse.
he is going to take the 5.13 gear out and put some 4.56 gears in before next week, should get it real close.
he left at only 3400 from the line, and short shifted it into second gear, not sure he was going to run it out on the first and only pass.
my opinion is that with the correct gear, good air, and leaving at 4500 ish(and considering he hasnt even looked at jetting or put a timing light on it)the car should dip into the 9.40's rather easily with an electric water pump on it.
not to bad with that little 248@50 "puppy" cam in it..........mighty impressive, and as they run those things on 100 octane fuel, and he was running 110 in it, i have no doubt it will like a little more timing than the 30-32 degrees we suspect it had in it last night....he was happy, and considering the frontend is a custom one off piece, to go straight down the track and have the car hook on a 28 inch tire was impressive.....
1.41 best 60 foot
6.60 at 103.90 1/8
Re: R5P7 DART TO TEST FRIDAY [Re: scottb] #364249
07/04/09 11:57 AM
07/04/09 11:57 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
Great to hear. Nice numbers, especially 60` time! As we dont still have no special race track ( covered with this "glue" ) here where I live, we are useing old airfields for racing, then I want to ask that on what kind of race track you were? Was it "covered with glue" Hopefully you understand what I mean...
You may take a look of our race track conditions here : http://dragracing.ee/pictures/v/Speedest+Nightrace+2009/?g2_page=1
Just seems to me that 60` time is impressive with 10,5" slick.
How much you think helps water pump swap from mechanical to electric?
Did someone made vid clip maybe?
Page 2 of 4 1 2 3 4
