Re: BG400 Pump
[Re: moparatheart]
#362120
06/30/09 12:08 AM
06/30/09 12:08 AM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
Magnafuel if those are my only choices. Why not look at Product Engineering as well, good pumps good people and they were the fore runners of the Magnafuels.
Re: BG400 Pump
[Re: Al_Alguire]
#362121
06/30/09 12:41 AM
06/30/09 12:41 AM
Posts: 457 Fort Wayne, IN
moparatheart
Fort Wayne, IN
Thank you Al_Alguire. Also, for those that are not familar with our set up and it would help them base their opinion it is as follows:
9.20" R3 block, 50 MM cam tunnel 3.64" stroke King billet crank(48 lbs) GRP 1100 series 6.25 alum rods CP domes, lateral gas ports, .043/043/3MM rings 437 gram 1564 Bobweight Custom Charlies oil pan, Stock Car Products pump 16.0:1 compression Custom Comp roller, 278/300 @ .050" 112 LSA, installed at 111 .790/.735" lift, 1.7/1.55 Jesels 3/8 Comp pushrods Crower SD .180 offset .842 lifters Heads are old Ritter/Weber Arrington heads, 2.15"/1.625" Del Wests, 45* seats, 36 CC chamber, 255 CC runner, 2.78" Min CSA. Flow 354/255 @ .700 Hogans Sheetmetal intake, 2 1050 Dominators Weber belt drive, MSD trigger, ATI steel hub 2 ring damper.
Was 800+ HP when Ryan Johnson Dynoed it.
Re: BG400 Pump
[Re: moparatheart]
#362122
06/30/09 01:05 AM
06/30/09 01:05 AM
Al_Alguire
Las Vegas
I actually have a BG fuel pump still. I have not had any issues with it but if I ever did I woudl replace it with a PE.
Re: BG400 Pump
[Re: Al_Alguire]
#362124
06/30/09 07:35 AM
06/30/09 07:35 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
BG400-2 Titanium here....no leaks....no problems....the original BG400 sat for four years and didn't leak when I installed the new bullet but it was corroded beyond repair internally due to the previous owner not draining the alky
Rickster
Re: BG400 Pump
[Re: Al_Alguire]
#362125
06/30/09 08:18 AM
06/30/09 08:18 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Product Engineering makes excellent stuff. Mine is quiet and was the only pump that can be mounted above the fuel tank and not have a warranty disclaimer in the instructions if you do so. Great customer service too.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: BG400 Pump
[Re: BB70DUSTER]
#362129
06/30/09 05:42 PM
06/30/09 05:42 PM
rickstershemi
I had 3 or 4 BG280s poop the bed before I went to Magnafuel, never a problem since... have them in both my cars... BGs customer service was horrible too!!!
Funny I have read about all the horror stories everyone claims with BG....but I have had nothing but great service from BG & their tech/service people...
Rickster
Re: BG400 Pump
[Re: rickstershemi]
#362130
06/30/09 05:50 PM
06/30/09 05:50 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
A buddy just put a brand new aeromotive pump on his car and it was seized up right out of the box..luckily he found another brand to use as a spare.
The one that was bad out of the box was a 2000 from Aeromotive
Re: BG400 Pump
[Re: rickstershemi]
#362131
06/30/09 06:15 PM
06/30/09 06:15 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
Rickster
2 of the 4 times I felt like the guy thought I was dumb... kept trying to make it my fuel systems fault, even though it was up too their standards... the other times it just took them forever, and the repairs cost be within $20 of what a new pump would have cost...
Re: BG400 Pump
[Re: BB70DUSTER]
#362132
06/30/09 06:19 PM
06/30/09 06:19 PM
rickstershemi
Rickster
Just expressing my past experience...maybe I've just been lucky.....
Rickster
Re: BG400 Pump
[Re: NITROUSN]
#362137
06/30/09 10:22 PM
06/30/09 10:22 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
My 280 started resonating and would spit fuel instead of flow, but in a narrow window - - right where my car needed going down the track. BG repaired it, then replaced it then gave up and then sent me a 400. All at no charge. Cost me a lot of money as I needed to replace all of the lines - - all braided.
One thing I have to say is that BG service was great.......
Re: BG400 Pump
[Re: markz528]
#362138
06/30/09 10:33 PM
06/30/09 10:33 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Interesting comments. My BG 400 is 20 years old. I pull the carb lines to check the volume every now and then and 1 gal in 14 secs...never heard of a BG400 failure...so it will fail on the first pass next time and then buy.
The little old lady from Pasadena is back!
