Were to get HP manifold flanges #354183
06/21/09 11:14 PM
06/21/09 11:14 PM
Woodbridge,CA
NAS Backyard Offline OP
Woodbridge,CA
I'm trying to fix an exhaust leak on my HP manifolds.I checked by hand and the leak is at the flange even with 2 gaskets. The exhaust guy used some crap flanges to begin with , then I went from 383 to 440 and had to tweek the pipes to fit. Now I want to start over with new flanges and start with 3" pipe and go all the way back, I currently have 2 1/2" with 2" tail pipes. Weres a good vender to find these parts at? Maybe they are a stock item at an exhaust shop. I want a hole to hole fit with no slotted holes or sloppy fit though.Thanks
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: Were to get HP manifold flanges [Re: NAS Backyard] #354184
06/21/09 11:20 PM
06/21/09 11:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
http://www.accurateltd.com/Flanges_c_10.html
I had a similar leak, what Tom from Accurate suggested & I did with good results was bolt the headpipe to the manifold with the new flange sandwiched between the old flange & the headpipe... Tack the two flanges together then drop the pipe down & fully weld it.. Winds up with a 1/2" thick flange & no more leaks...
Re: Were to get HP manifold flanges [Re: 1_WILD_RT] #354185
06/21/09 11:30 PM
06/21/09 11:30 PM
Woodbridge,CA
Woodbridge,CA
Excellent idea Randy! I checked Accurate and they have the 2 1/2" flanges. I beat the crap out of my pipes when I went to the 440 so I want to clean everything up and also install an H pipe.Is it even practical to try and run 3" off the manifold? BTW, I found my engine problem, loose torque converter bolts (like hand tight, doh!) I also found a guy to build my engine to go 12's at a decent price.
Re: Were to get HP manifold flanges [Re: NAS Backyard] #354186
06/21/09 11:39 PM
06/21/09 11:39 PM
When Andy did it w his 470(alum heads & 68-70 hp manifolods) he made iirc 550 hp
Re: Were to get HP manifold flanges [Re: NAS Backyard] #354187
06/22/09 01:01 AM
06/22/09 01:01 AM
AndyF Offline
AndyF  Offline
Here is the 3 inch to HP manifold setup that I had built for my car. I don't know anyone who sells these parts, I had to have this stuff all fabricated for my project.
Re: Were to get HP manifold flanges [Re: AndyF] #354188
06/22/09 02:26 AM
06/22/09 02:26 AM
Woodbridge,CA
Woodbridge,CA
That is a Rude set-up! Sweet Work! OK, I know it can be done, just need to find someone with a CNC machine.I might be able to hog out the 2 1/2" ones. Is that an O2 sensor for tuning?
Re: Were to get HP manifold flanges [Re: NAS Backyard] #354189
06/22/09 10:28 AM
06/22/09 10:28 AM
AndyF Offline
AndyF  Offline
Yes, I put an O2 bung in each head pipe so I can run a wide band setup on either side.
Re: Were to get HP manifold flanges [Re: NAS Backyard] #354190
06/22/09 11:48 AM
06/22/09 11:48 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
TTI sells a set of 3" head pipes.. $188.00
http://www.ttiexhaust.com/ComponentParts/ExhaustParts.htm#ep
Re: Were to get HP manifold flanges [Re: 1_WILD_RT] #354191
06/22/09 12:32 PM
06/22/09 12:32 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
Or right below the headpipes they show the H-pipe like you want too, even says it clears the GV unit. 222.00 $.
Butch
