Were to get HP manifold flanges
#354183
06/21/09 11:14 PM
06/21/09 11:14 PM
Posts: 5,449 Woodbridge,CA
NAS Backyard
Woodbridge,CA
I'm trying to fix an exhaust leak on my HP manifolds.I checked by hand and the leak is at the flange even with 2 gaskets. The exhaust guy used some crap flanges to begin with , then I went from 383 to 440 and had to tweek the pipes to fit. Now I want to start over with new flanges and start with 3" pipe and go all the way back, I currently have 2 1/2" with 2" tail pipes. Weres a good vender to find these parts at? Maybe they are a stock item at an exhaust shop. I want a hole to hole fit with no slotted holes or sloppy fit though.Thanks
1970 Challenger Ragtop 426 4 speed
1961 Olds 88 2 dr Sedan 394 4 speed GVOD
1968 Pontiac Firebird 428 4 speed
2000 Ford F-150
2002 HD Roadking
1961 Licence Plate collection
1995 Buick Roadmaster
www.nogreenautolaws.com
Re: Were to get HP manifold flanges
[Re: 1_WILD_RT]
#354185
06/21/09 11:30 PM
06/21/09 11:30 PM
NAS Backyard
Woodbridge,CA
Excellent idea Randy! I checked Accurate and they have the 2 1/2" flanges. I beat the crap out of my pipes when I went to the 440 so I want to clean everything up and also install an H pipe.Is it even practical to try and run 3" off the manifold? BTW, I found my engine problem, loose torque converter bolts (like hand tight, doh!) I also found a guy to build my engine to go 12's at a decent price.
2000 Ford F-150
2002 HD Roadking
