Mini tubs '70 B body #351660
06/19/09 09:48 AM
06/19/09 09:48 AM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
How wide of a wheel/tire would I be able to fit if I mini-tubbed my Super Bee? I am thinking of doing it like this:
http://www.hotrod.com/techarticles/body/hrdp_0903_diy_mini_tubbing_guide/photo_01.html
They never say how many inches they got from the procedure. I would imagine 2-3"and I could go measure to get a good idea... but how many inches do you get from the spring relocation?
I'd kinda like to shorten my rear end as well for a deeper wheel (or buy a shortened rear). What's the best option considering I was already planning on changing my ring and pinion?
Re: Mini tubs '70 B body [Re: PAINT IT BLACK] #351661
06/19/09 10:44 AM
06/19/09 10:44 AM
Texas
RaiderLefty Offline
RaiderLefty  Offline
Texas
How wide of a rear are you wanting to run? I have a '68 RR and I'm currently running a 305/40/18 on a 10" width rim with absolutely no problem.
I would think you'd only want to mini-tub if you're planning on running a 12" width rim which was a little too wide for my tastes.
FYI........I'm located in Houston if you want to have a look at mine.
Re: Mini tubs '70 B body [Re: RaiderLefty] #351662
06/19/09 10:50 AM
06/19/09 10:50 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
A SB has even more room than a RR. One of the nice things about a '68 - '70 B body is how much bigger of a tire you can fit than the GM A body guys. I have 275/60/15's which are a big tire to me, but I would think you could fit a 305 or even a 315 in there without going with the mini-tub.
What size are your TT's and tires now, Steve?
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Mini tubs '70 B body [Re: RaiderLefty] #351663
06/19/09 11:05 AM
06/19/09 11:05 AM
Houston Texas
Houston Texas
It might be too wide for all I know, really. What I am pondering is getting a deep look to my rear wheels. Kinda like a Pro street look, only not so cheezy and overblown... Probably run some Weld wheels or the like if I do it. I'd like to see pics if anyone has any.
And you haven't relocated your springs, right?
Re: Mini tubs '70 B body [Re: DPelletier] #351664
06/19/09 11:17 AM
06/19/09 11:17 AM
Houston Texas
Houston Texas
They are 8.5" TT with 295/50R15 Firehawks. They are too short of a tire for one, and I really should go wider anyway with the plans I am concocting. I have 275/60R15 TA's on the Cuda's 8" Rallyes, and those tires would look better on the Bee, but I am definitely going with a drag radial anyway.
I am considering taking a different approach with the car than I had in mind before. I really am thinking of stuffing some major rolling stock in there and having the car sit pretty low over it all.
If I do this I am going to go tough looking all the way. My goal is for the car to not know whether it is a street car or a race car. Something that would almost be a race car if it didn't have a really nice paint job/engine bay and interior. Plus I am not really going to chop anything up other than possibly the inner fenders. I've added sub frame connectors, torque boxes, Hemi spring reinforcement plates, and a pinion snubber plate, but that's as far as the body mods will go.
I MAY be able to simply shorten the rear end to achieve what I am after. I'd most likely have to relocate the springs if I did that. But maybe I don't have to mini tub it to get the look I am going for. That would be a MAJOR plus... (I don't feel real good about chopping up this solid car).
Re: Mini tubs '70 B body [Re: PAINT IT BLACK] #351665
06/19/09 11:28 AM
06/19/09 11:28 AM
DPelletier Offline
DPelletier  Offline
Definitely do what makes you happy Steve, I just thought the car looked so good already!
Keep us updated!
Cheers,
Re: Mini tubs '70 B body [Re: DPelletier] #351666
06/19/09 12:15 PM
06/19/09 12:15 PM
Houston Texas
Houston Texas
Keep us updated!
Cheers,
I've got a tattoo on my inner arm that reads in Japanese "Never Satisfied" for a reason..
Re: Mini tubs '70 B body [Re: PAINT IT BLACK] #351667
06/19/09 12:56 PM
06/19/09 12:56 PM
DPelletier Offline
DPelletier  Offline
Re: Mini tubs '70 B body [Re: PAINT IT BLACK] #351668
06/19/09 01:52 PM
06/19/09 01:52 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
The springs are pretty much even with the factory tub at the factory. Making tubs is worthless without Spring relocation. You basically have to do both.
You can gain a lot by making the outer tub wall go straight up.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Mini tubs '70 B body [Re: HealthServices] #351669
06/19/09 01:58 PM
06/19/09 01:58 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
My dart is the same way. Unless you move the springs having a wider wheelhouse is pointless. I thought about doing mine, but once you move the springs then running the exhaust out the back becomes rather difficult. In the end I chose to leave it alone.
Re: Mini tubs '70 B body [Re: Neil] #351670
06/19/09 03:08 PM
06/19/09 03:08 PM
Houston Texas
Houston Texas
I just read an article where I guy had a 70 Road Runner and he used a 3.5" spring relocation kit, mini tubbed the car and went with 12" rims with 29X15.50-15 Hoosiers. The car looks pretty sweet, and that's a lot of rubber! It just might be what I am wanting. I might want a LITTLE taller tire if possible though? Maybe not.
I think I can move the inner wheel wells in and make it look pretty dang close to factory. It's kinda silly that they didn't just come that way to begin with. That 3" gap between the wheel well and the frame seems like such a waste.
Re: Mini tubs '70 B body [Re: PAINT IT BLACK] #351671
06/19/09 04:20 PM
06/19/09 04:20 PM
DPelletier Offline
DPelletier  Offline
Did you read the article in one of the mags a while back about a 1 of 9 (IIRC) '68 or '69 Hemi GTX Vert racecar? They had some info on tire and slick sizes in that article that might be interesting.
Re: Mini tubs '70 B body [Re: DPelletier] #351672
06/19/09 05:13 PM
06/19/09 05:13 PM
Houston Texas
Houston Texas
Hmmm... I do remember that... I'll look it up, thanks.
I went ahead and ordered a bead roller to fab a flanged filler piece as well as a spot weld remover, so it looks like I am going to do this.
Re: Mini tubs '70 B body [Re: PAINT IT BLACK] #351673
06/19/09 08:09 PM
06/19/09 08:09 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We ran 10" wide wheels with a 5" BS on our 70 'Beeper using a 10.5x29.5 drag slick.Had to trim the lip and a leading edge of the fenderwell,but it fit great.
Nautilus Racing-
Re: Mini tubs '70 B body [Re: PAINT IT BLACK] #351674
06/19/09 08:50 PM
06/19/09 08:50 PM
So Cal
So Cal
29 is a really really tall. You will have a stink bug look to it if you do not lower it some.
