Mini tubs '70 B body
#351660
06/19/09 09:48 AM
06/19/09 09:48 AM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
How wide of a wheel/tire would I be able to fit if I mini-tubbed my Super Bee? I am thinking of doing it like this: http://www.hotrod.com/techarticles/body/hrdp_0903_diy_mini_tubbing_guide/photo_01.htmlThey never say how many inches they got from the procedure. I would imagine 2-3"and I could go measure to get a good idea... but how many inches do you get from the spring relocation? I'd kinda like to shorten my rear end as well for a deeper wheel (or buy a shortened rear). What's the best option considering I was already planning on changing my ring and pinion?
Re: Mini tubs '70 B body
[Re: RaiderLefty]
#351662
06/19/09 10:50 AM
06/19/09 10:50 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
A SB has even more room than a RR. One of the nice things about a '68 - '70 B body is how much bigger of a tire you can fit than the GM A body guys. I have 275/60/15's which are a big tire to me, but I would think you could fit a 305 or even a 315 in there without going with the mini-tub.
What size are your TT's and tires now, Steve?
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: RaiderLefty]
#351663
06/19/09 11:05 AM
06/19/09 11:05 AM
PAINT IT BLACK
Houston Texas
How wide of a rear are you wanting to run? I have a '68 RR and I'm currently running a 305/40/18 on a 10" width rim with absolutely no problem.
I would think you'd only want to mini-tub if you're planning on running a 12" width rim which was a little too wide for my tastes.
FYI........I'm located in Houston if you want to have a look at mine.
It might be too wide for all I know, really. What I am pondering is getting a deep look to my rear wheels. Kinda like a Pro street look, only not so cheezy and overblown... Probably run some Weld wheels or the like if I do it. I'd like to see pics if anyone has any.
And you haven't relocated your springs, right?
[Re: PAINT IT BLACK]
#351665
06/19/09 11:28 AM
06/19/09 11:28 AM
DPelletier
Definitely do what makes you happy Steve, I just thought the car looked so good already! Keep us updated! Cheers, Dave
1974 'Cuda
[Re: DPelletier]
#351666
06/19/09 12:15 PM
06/19/09 12:15 PM
PAINT IT BLACK
Houston Texas
Keep us updated!
Cheers, Dave
I've got a tattoo on my inner arm that reads in Japanese "Never Satisfied" for a reason..
#351668
06/19/09 01:52 PM
06/19/09 01:52 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
The springs are pretty much even with the factory tub at the factory. Making tubs is worthless without Spring relocation. You basically have to do both.
You can gain a lot by making the outer tub wall go straight up.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#351669
06/19/09 01:58 PM
06/19/09 01:58 PM
Posts: 20,730 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
My dart is the same way. Unless you move the springs having a wider wheelhouse is pointless. I thought about doing mine, but once you move the springs then running the exhaust out the back becomes rather difficult. In the end I chose to leave it alone.
#351671
06/19/09 04:20 PM
06/19/09 04:20 PM
DPelletier
Did you read the article in one of the mags a while back about a 1 of 9 (IIRC) '68 or '69 Hemi GTX Vert racecar? They had some info on tire and slick sizes in that article that might be interesting.
1974 'Cuda
[Re: DPelletier]
#351672
06/19/09 05:13 PM
06/19/09 05:13 PM
PAINT IT BLACK
Houston Texas
Hmmm... I do remember that... I'll look it up, thanks.
I went ahead and ordered a bead roller to fab a flanged filler piece as well as a spot weld remover, so it looks like I am going to do this.
#351673
06/19/09 08:09 PM
06/19/09 08:09 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
We ran 10" wide wheels with a 5" BS on our 70 'Beeper using a 10.5x29.5 drag slick.Had to trim the lip and a leading edge of the fenderwell,but it fit great.
