440source mini-starter terminal clearance #351207
06/18/09 08:35 PM
06/18/09 08:35 PM
Ohio
jensenguy Offline OP
Ohio
Im finally getting back to trying to install this new mini-starter on my 440. I notice that the battery positive stud (w/nut) on the starter is less than a 1/4 of an inch away from the block - probably would be around 1/8 of an inch with the cable installed. Oh and this is with the terminal extension removed - that would in no way fit.
Now in my experience, a main battery positive cable is something I want to keep away from a large grounded chunk of cast iron. Are these mini-starters really made this way? If so, can someone give me any ideas on how to try to insulate this connection?
thanks
Re: 440source mini-starter terminal clearance [Re: jensenguy] #351208
06/18/09 09:25 PM
06/18/09 09:25 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I cut a 3/8 inch long piece of rubber fuel line. After the + cable and nut are installed and tight, I slip the piece of hose over the top of the starter stud and wedge it against the block.
Simple, cheap, and the rubber hose insulates the stud. 4 years and no problems.
I've heard of guys who run without any insulation at all with no problems either, but this simple fix makes me feel better.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: 440source mini-starter terminal clearance [Re: jensenguy] #351209
06/18/09 09:31 PM
06/18/09 09:31 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I just stuck a mini starter on my Interceptor, I tossed the connection extension and I seem to have acceptable clearance, but I know some are better than others...
CrAzYMoPaRGuY
Re: 440source mini-starter terminal clearance [Re: wingman] #351210
06/18/09 09:34 PM
06/18/09 09:34 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
That's the same way I did it.
Re: 440source mini-starter terminal clearance [Re: Lefty] #351211
06/18/09 10:32 PM
06/18/09 10:32 PM
Ohio
Ohio
thanks guys, I'll try to find something like that. I am considering doing some soldering and grinding and making a permanently installed positive cable with more clearance, it may work out better for this application. Depends on how bored i get at work.
thanks again!
Re: 440source mini-starter terminal clearance [Re: CrAzYMoPaRGuY] #351212
06/19/09 10:21 PM
06/19/09 10:21 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I tossed the extention too, and did some grinding on the remaining tab to maximize the clearance to the block.
Re: 440source mini-starter terminal clearance [Re: jbc426] #351213
06/20/09 04:23 PM
06/20/09 04:23 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
tossing the exension is a necessity on a BB with the mini starter
Re: 440source mini-starter terminal clearance [Re: jensenguy] #351214
06/20/09 05:26 PM
06/20/09 05:26 PM
CHRGR69 Offline
CHRGR69  Offline
Get the mini starter from Robb Mc Performance. PN2005. Unreal clearance.
Grandma always said I had "hands of gold"!
Re: 440source mini-starter terminal clearance [Re: CHRGR69] #351215
06/20/09 06:28 PM
06/20/09 06:28 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The McRobb Starter is a very nice piece but it is three times the money... To keep $200.00 in my pocket I'll deal with a minor inconvience...
Re: 440source mini-starter terminal clearance [Re: 1_WILD_RT] #351216
06/20/09 07:51 PM
06/20/09 07:51 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
After the second time I replace my stock mini starter I decided I only want to pull this thing out one time.
I got a McRobb starter.
Parts are available for them too on the website.
And he supports Moparts by using ad space on this forum.
https://board.moparts.org/ubbthreads/show...rue#Post5111743
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
