balance on torque converter?? #348374
06/15/09 09:45 PM
06/15/09 09:45 PM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
changed 318 to a 360 in the 38 but left 318 trans in so instead of welding weights on converter my brother had a flex plate from summit i could use well put it in and starter just spins flex plate was used with a 727 my tran is a 904 the cylinder that pushes the gear in hits about 1/8 to big so is there a light weight starter that might clear or does summit sell a flex plate for a 904 or weld weights to converter??did't really want to drop tranny again Thanks
Re: balance on torque converter?? *DELETED* [Re: beesting] #348375
06/15/09 11:24 PM
06/15/09 11:24 PM
scratchnfotraction Offline
Post deleted by scratchnfotraction
Re: balance on torque converter?? [Re: scratchnfotraction] #348376
06/15/09 11:49 PM
06/15/09 11:49 PM
md
mopars4ever Offline
mopars4ever  Offline
md
summit has them for a 904 both with or without external balance
Re: balance on torque converter?? [Re: scratchnfotraction] #348377
06/16/09 04:07 PM
06/16/09 04:07 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
uhh!! I am missing some thing here
Me too, punctuation would help.
Re: balance on torque converter?? *DELETED* [Re: John_Kunkel] #348378
06/16/09 05:12 PM
06/16/09 05:12 PM
Re: balance on torque converter?? [Re: scratchnfotraction] #348379
06/16/09 05:29 PM
06/16/09 05:29 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
sorry...
only went to the 8th grade.
cant spell either.
barly can type/write.
my bad...I will not post on here any more,if its a bother to you...
Kunkle wasnt referring to you. Now you missed something twice. mikie
Re: balance on torque converter?? *DELETED* [Re: Sport440] #348380
06/16/09 06:08 PM
06/16/09 06:08 PM
Re: balance on torque converter?? [Re: scratchnfotraction] #348381
06/16/09 06:39 PM
06/16/09 06:39 PM
md
mopars4ever Offline
mopars4ever  Offline
md
trust me,I missed it a lot more than 2 times for sure
its only been the umpteenth time I have been told to punch and wait here on this board
I know I am a dumb azz hickabilly shadetree rabid parts changer
I am doing the best I can do with what little brain I have
so now I return you to the topic at hand
At least you try to help others with their problems. Some members here never venture to Q&A side of the board. All they want to do is talk politics, etc. Maybe they don`t know enough to help out.
Re: balance on torque converter?? [Re: mopars4ever] #348382
06/16/09 07:16 PM
06/16/09 07:16 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
You need the flex plate for the 904 transmission and external balance 360. Available at summit.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: balance on torque converter?? [Re: MoparforLife] #348383
06/16/09 08:14 PM
06/16/09 08:14 PM
lisbon,ohio
beesting Offline OP
Still a member
beesting  Offline OP
Still a member
lisbon,ohio
I really am a high school grad.I was just in a hurry to type it and did't prove read it real good, I knew what i was tring to say , sorry Thanks for the answers
