Re: Very slow spinning engine New build
[Re: PlumCrazyCharger]
#345878
06/13/09 04:57 PM
06/13/09 04:57 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I would start with the simple things first. (1) do you have a fully charged battery and (2) do you have good ground from the engine thru the body and back to the battery? I used to do road service calls and threw a new battery and rebuilt starter at no-start Isuzu diesel pickup. On the 3rd visit,I found a loose ground at the engine block after I fixed that, I never heard from them again
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
#345882
06/13/09 05:36 PM
06/13/09 05:36 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Let me throw something out there...
Just finished a street 440 for my 69 Charger just freshened everything and lowered the compression. The engine turns over freely by hand and when I go to start it the starter seems to labor and spins the engine over extreemly slowly. Car will not start. It kinda sounds like reen o reen o reen o reen
Just threw in a brand new battery (1st thought) it has spark slowly turns over with ignition off and coil/ distributor disconnected, almost as quickely as you could spin it by hand! spins a little quicker with the spark plugs out, but not anywhere close to what it should be Plugs do have a bit of fuel on them (did not flood it just enough to start)
The starter was a little harder to get in than normal, so could the starter by misaligned ? Before I take the starter out I figured I would ask you guys. It's a pain in the ass to get it out.
On Sunday I might loosen the starter and reinstall. Help!
Happened to me same deal starter drive was jammed against the flywheel and dragged bad....
Rickster
[Re: rickstershemi]
#345886
06/14/09 07:29 PM
06/14/09 07:29 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
Rickster
This is probably the culprit
