Very slow spinning engine New build #345876
06/13/09 04:47 PM
06/13/09 04:47 PM
Chi-Town
PlumCrazyCharger Offline OP
Chi-Town
Let me throw something out there...
Just finished a street 440 for my 69 Charger just freshened everything and lowered the compression. The engine turns over freely by hand and when I go to start it the starter seems to labor and spins the engine over extreemly slowly. Car will not start. It kinda sounds like reen o reen o reen o reen
Just threw in a brand new battery (1st thought) it has spark
slowly turns over with ignition off and coil/ distributor disconnected, almost as quickely as you could spin it by hand!
spins a little quicker with the spark plugs out, but not anywhere close to what it should be
Plugs do have a bit of fuel on them (did not flood it just enough to start)
The starter was a little harder to get in than normal, so could the starter by misaligned? Before I take the starter out I figured I would ask you guys. It's a pain in the ass to get it out.
On Sunday I might loosen the starter and reinstall. Help!
Re: Very slow spinning engine New build [Re: PlumCrazyCharger] #345877
06/13/09 04:54 PM
06/13/09 04:54 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
One thing to look is ground wire size. Do you have a good engine ground for that starter? If not see if you can measure the starter on how much it draws while cranking. A secondary way to do this is to measure battery voltage while cranking.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Very slow spinning engine New build [Re: PlumCrazyCharger] #345878
06/13/09 04:57 PM
06/13/09 04:57 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I would start with the simple things first. (1) do you have a fully charged battery and (2) do you have good ground from the engine thru the body and back to the battery?
I used to do road service calls and threw a new battery and rebuilt starter at no-start Isuzu diesel pickup. On the 3rd visit,I found a loose ground at the engine block after I fixed that, I never heard from them again
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Very slow spinning engine New build [Re: PlumCrazyCharger] #345879
06/13/09 05:09 PM
06/13/09 05:09 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Could be a bad ground, check your connections,test voltage drop at the starter and batt while cranking if its more than .5 volts you have a connection or cable problem, load test batt, If all else fails pull the starter and have it tested , check flywheel teeth for signs of miss alignment
Re: Very slow spinning engine New build [Re: emarine01] #345880
06/13/09 05:15 PM
06/13/09 05:15 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
TRY using some starting fluid. And aslo check that starter alignment.
Re: Very slow spinning engine New build [Re: dOc !] #345881
06/13/09 05:27 PM
06/13/09 05:27 PM
Iowa
coronetville Offline
Iowa
check timing, did you put in new main bearings? did you check bearing clearance?
Re: Very slow spinning engine New build [Re: PlumCrazyCharger] #345882
06/13/09 05:36 PM
06/13/09 05:36 PM
Lehigh Acres, Florida
rickstershemi Offline
The starter was a little harder to get in than normal, so could the starter by misaligned ? Before I take the starter out I figured I would ask you guys. It's a pain in the ass to get it out.
Happened to me same deal starter drive was jammed against the flywheel and dragged bad....
Rickster
Re: Very slow spinning engine New build [Re: rickstershemi] #345883
06/13/09 09:54 PM
06/13/09 09:54 PM
Chi-Town
Chi-Town
Could be a ground? I do have it grounded, but never hurts to recheck. After that I'll pull the starter and check for mis-alignment.
Re: Very slow spinning engine New build [Re: PlumCrazyCharger] #345884
06/13/09 11:45 PM
06/13/09 11:45 PM
so cal
cmcgee123 Offline
cmcgee123  Offline
so cal
my 440 did that after i rebuilt the engine. i put in a powermaster starter that cured my problem.
Re: Very slow spinning engine New build [Re: cmcgee123] #345885
06/13/09 11:55 PM
06/13/09 11:55 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
I had the same problem and it turned out being a bad ground. I got the car started and noticed that by having the bad ground it melted the shifter cable.
Re: Very slow spinning engine New build [Re: rickstershemi] #345886
06/14/09 07:29 PM
06/14/09 07:29 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Rickster
This is probably the culprit
