Headers for a 1965 Dodge Coronet with a 440 #339211
06/05/09 10:47 PM
06/05/09 10:47 PM
Anonymous OP
Anonymous OP
I need help finding a set of headers that will fit a 1965 Dodge Coronet with a 440? I have a set of Headman Elite Headers and they are nice but they rub on the drivers side torsion bar. Need a recommendation for a set that has good clearance, TTI or Dougs Headers?
Clint
Re: Headers for a 1965 Dodge Coronet with a 440 #339212
06/05/09 10:54 PM
06/05/09 10:54 PM
central illinois
65dodgebob Offline
65dodgebob  Offline
central illinois
dougs headers are great. good fit, no dinging required, coating looks great,too. i was pleased.
Re: Headers for a 1965 Dodge Coronet with a 440 [Re: 65dodgebob] #339213
06/06/09 07:45 AM
06/06/09 07:45 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I'm using TTI's. The first set of headers I've ever installed that didn't require any tube denting.
Re: Headers for a 1965 Dodge Coronet with a 440 [Re: TooMany62s] #339214
06/06/09 11:33 AM
06/06/09 11:33 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i have tti`s on mine they fit great. if you want 3" exhaust pipes you will have to notch the trans cross member.
Re: Headers for a 1965 Dodge Coronet with a 440 [Re: 65dodgebob] #339215
06/06/09 12:02 PM
06/06/09 12:02 PM
Anonymous OP
Anonymous OP
What type of header did you go with? Did you use a long tube or a fenderwell header?
Clint
Re: Headers for a 1965 Dodge Coronet with a 440 #339216
06/06/09 03:59 PM
06/06/09 03:59 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I ran TTI 2" underchassis headers on my 65 Coronet wagon with a 440/stock heads and also 470/400 stroker/Indy heads. Fit perfect on both engines with no issues whatsoever. Great headers.
2 kids and a dog
Re: Headers for a 1965 Dodge Coronet with a 440 [Re: TonyS451] #339217
06/06/09 06:09 PM
06/06/09 06:09 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
I have TTI's and they fit very well, the only complaint I have is that they wanted more for them plain than with the stupid chrome plating, I would have much preferred ceramic but like everything else today, we are only the stupid consumer, customer service is gone, gone, gone.
Joey
Re: Headers for a 1965 Dodge Coronet with a 440 [Re: 65dodgebob] #339218
06/06/09 09:04 PM
06/06/09 09:04 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Another vote here for Dougs very good welding and coating job and cost less than TTI's with a 2" tube with 3 1/2" collector.
Gus
64 Plymouth Savoy
Dana 60
Re: Headers for a 1965 Dodge Coronet with a 440 [Re: fourgearsavoy] #339219
06/08/09 09:43 AM
06/08/09 09:43 AM
Anonymous OP
Anonymous OP
Are your headers fenderwell or under chassis?
Clint
Re: Headers for a 1965 Dodge Coronet with a 440 #339220
06/08/09 02:44 PM
06/08/09 02:44 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
mine are under chassis
Re: Headers for a 1965 Dodge Coronet with a 440 #339221
06/08/09 05:11 PM
06/08/09 05:11 PM
SCVpolara Offline
SCVpolara  Offline
I have some cheap Headmans on my 64 with a 440. They actually fit well with no dinging. Clears power steering. The collecter flange could be thicker but you get what you pay for. These were free.
Re: Headers for a 1965 Dodge Coronet with a 440 [Re: SCVpolara] #339222
06/08/09 06:12 PM
06/08/09 06:12 PM
dart1962_440 Offline
Anyone have experience with the Headman's and a low deck in an early B?
Re: Headers for a 1965 Dodge Coronet with a 440 [Re: dart1962_440] #339223
06/08/09 06:24 PM
06/08/09 06:24 PM
SCVpolara Offline
SCVpolara  Offline
These were on a 383 that was in the car. The clearance should be better than with a r/b. No starter clearance issues either.
Re: Headers for a 1965 Dodge Coronet with a 440 [Re: dart1962_440] #339224
06/08/09 06:26 PM
06/08/09 06:26 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I'm running them in a 64 Polara with a 383,no problems. They would hit a small MP starter when I had them in a 63 Plym. with a 440. Ok with stock starter.
Re: Headers for a 1965 Dodge Coronet with a 440 [Re: pushbutton] #339225
06/08/09 06:46 PM
06/08/09 06:46 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
2" tti's here. pefect fit.
