HELP...Intake gasket question...what is wrong here?
#338794
06/05/09 04:23 PM
06/05/09 04:23 PM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
Putting the intake back in and noticed the center heat cross-over "upside down U" shaped holes are not covered by the new FelPro gaskets. Is this right?
Still looking for LM29H1B415501, '71 Demon 340
Re: Intake gasket question...what is wrong here?
[Re: PAULS_340]
#338795
06/05/09 04:28 PM
06/05/09 04:28 PM
Posts: 13,595 md
mopars4ever
md
[Re: mopars4ever]
#338796
06/05/09 04:47 PM
06/05/09 04:47 PM
PAULS_340
Motown, Mi
What's the purpose of that open area...by the way, imo the FelPro look like *&^*(. And when you use the stupid plastic cup rings it holds the intake up so it doesn't set on the heads???
[Re: PAULS_340]
#338797
06/05/09 04:51 PM
06/05/09 04:51 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
its for putting your butts out while your are smoking under the hood.....
I am truckless..
[Re: mopars4ever]
#338800
06/05/09 06:37 PM
06/05/09 06:37 PM
Posts: 4,280 Medford OR
FrankenScamp
Medford OR
I use the MR Gasket paper style gaskets on my 340. I don`t like the blue felpro ones.
dont say that! I just put those on my 340..... whats so bad about them??
[Re: mopars4ever]
#338801
06/05/09 06:37 PM
06/05/09 06:37 PM
Posts: 292 dead center
CHRONiklyDEMONic
Demonized
Demonized
dead center
I grease my intake gaskets and reuse them.
"After a Day filled with burning Rubber, you may find it time to re-tire."
[Re: CHRONiklyDEMONic]
#338802
06/05/09 06:46 PM
06/05/09 06:46 PM
PAULS_340
Motown, Mi
I just took a pic of the intake gasket but its too large to send here...
[Re: PAULS_340]
#338803
06/05/09 07:30 PM
06/05/09 07:30 PM
RapidRobert
Those plastic cup thingies are the wrong dia & wont work, I super glue(or something similar) to hold the side gaskets in place & I always use some gasket cement on both sides of the port openings(SPARINGLY) whether it calls for it or not . As said you want those horseshoe openings left open if you have a functioning heat riser(I dont like it functioning) , too much heat & affects the volatility of todays fuels. If not functioning you could cover it if you so desire(they do look ugly)
[Re: RapidRobert]
#338804
06/06/09 11:03 AM
06/06/09 11:03 AM
PAULS_340
Motown, Mi
How do you cover the upsidedown crossover holes? Do you need special gaskets?
[Re: PAULS_340]
#338805
06/06/09 11:13 AM
06/06/09 11:13 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
The horseshoe shaped passages are air damns to break up the heat collection from the 2 inner exhaust valves and the heat cross over all being united with out some sort of break up between them would create a very hot spot in the center of the heads. They actually do not go into anything and have no gasket coverage they remain wide open.
[Re: MoparforLife]
#338806
06/06/09 05:05 PM
06/06/09 05:05 PM
PAULS_340
Motown, Mi
Thank you. That's what I was looking for.
[Re: PAULS_340]
#338807
06/06/09 10:47 PM
06/06/09 10:47 PM
Posts: 13,595 md
mopars4ever
md
I feel that the paper type gaskets seal better. You should be fine.
