HELP...Intake gasket question...what is wrong here? #338794
06/05/09 04:23 PM
06/05/09 04:23 PM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
Putting the intake back in and noticed the center heat cross-over "upside down U" shaped holes are not covered by the new FelPro gaskets. Is this right?
Still looking for LM29H1B415501, '71 Demon 340
Re: Intake gasket question...what is wrong here? [Re: PAULS_340] #338795
06/05/09 04:28 PM
06/05/09 04:28 PM
md
mopars4ever Offline
mopars4ever  Offline
md
yes
Re: Intake gasket question...what is wrong here? [Re: mopars4ever] #338796
06/05/09 04:47 PM
06/05/09 04:47 PM
Motown, Mi
P
P
Motown, Mi
What's the purpose of that open area...by the way, imo the FelPro look like *&^*(. And when you use the stupid plastic cup rings it holds the intake up so it doesn't set on the heads???
Re: Intake gasket question...what is wrong here? [Re: PAULS_340] #338797
06/05/09 04:51 PM
06/05/09 04:51 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
its for putting your butts out while your are smoking under the hood.....
I am truckless..
Re: Intake gasket question...what is wrong here? [Re: 340SHORTY] #338798
06/05/09 05:40 PM
06/05/09 05:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It's for cooling the heat cross over area on the head.
Re: Intake gasket question...what is wrong here? [Re: stumpy] #338799
06/05/09 05:47 PM
06/05/09 05:47 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I use the MR Gasket paper style gaskets on my 340. I don`t like the blue felpro ones.
Re: Intake gasket question...what is wrong here? [Re: mopars4ever] #338800
06/05/09 06:37 PM
06/05/09 06:37 PM
Medford OR
FrankenScamp Offline
Medford OR
dont say that! I just put those on my 340..... whats so bad about them??
Re: Intake gasket question...what is wrong here? [Re: mopars4ever] #338801
06/05/09 06:37 PM
06/05/09 06:37 PM
dead center
CHRONiklyDEMONic Offline
Demonized
Demonized
dead center
I grease my intake gaskets and reuse them.
"After a Day filled with burning Rubber, you may find it time to re-tire."
Re: Intake gasket question...what is wrong here? [Re: CHRONiklyDEMONic] #338802
06/05/09 06:46 PM
06/05/09 06:46 PM
Motown, Mi
P
P
Motown, Mi
I just took a pic of the intake gasket but its too large to send here...
Re: Intake gasket question...what is wrong here? [Re: PAULS_340] #338803
06/05/09 07:30 PM
06/05/09 07:30 PM
Those plastic cup thingies are the wrong dia & wont work, I super glue(or something similar) to hold the side gaskets in place & I always use some gasket cement on both sides of the port openings(SPARINGLY) whether it calls for it or not . As said you want those horseshoe openings left open if you have a functioning heat riser(I dont like it functioning) , too much heat & affects the volatility of todays fuels. If not functioning you could cover it if you so desire(they do look ugly)
Re: Intake gasket question...what is wrong here? [Re: RapidRobert] #338804
06/06/09 11:03 AM
06/06/09 11:03 AM
Motown, Mi
P
P
Motown, Mi
How do you cover the upsidedown crossover holes? Do you need special gaskets?
Re: Intake gasket question...what is wrong here? [Re: PAULS_340] #338805
06/06/09 11:13 AM
06/06/09 11:13 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
The horseshoe shaped passages are air damns to break up the heat collection from the 2 inner exhaust valves and the heat cross over all being united with out some sort of break up between them would create a very hot spot in the center of the heads. They actually do not go into anything and have no gasket coverage they remain wide open.
Re: Intake gasket question...what is wrong here? [Re: MoparforLife] #338806
06/06/09 05:05 PM
06/06/09 05:05 PM
Motown, Mi
P
P
Motown, Mi
Thank you. That's what I was looking for.
Re: Intake gasket question...what is wrong here? [Re: PAULS_340] #338807
06/06/09 10:47 PM
06/06/09 10:47 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I feel that the paper type gaskets seal better. You should be fine.
