First fire on Magnum...duh!!
#336533
06/02/09 06:50 PM
06/02/09 06:50 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
'94 5.9l Magnum in my 67 Barracuda Ok...this afternoon was the first turn of the engine, I was not too wooried as I kept the starting system from the 67, so the engine turns on key Next I wanted to see if there was saprks to the plugs...but no sparks while cranking....that is my problem for start....and no current to the coil FRom the PCM, I installed the auto shut down relay and pump realy, supplied the PCM with 12v feed....I did not hold the starter relay from the '94, and the Park/neutral switch is not connected to the trans, I kept the 67 904 switch to go with the car wiring... Can anyone give me several ideas to where I missed ? Thanks Daniel
Re: First fire on Magnum...duh!!
[Re: Wedgeman]
#336540
06/04/09 06:56 PM
06/04/09 06:56 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Are you using the 94 Sbec II ECU or something else?
Leave the gun.......take the Cannoli's....Mike
